Simply tap twice on the orange light and your pad will be working again,
this is basically a lock like the HP had in earlier which was made enable/disable by Fn+F7 key,
As a new advancement its a lock and also indicator, when you see orange light it means that touchpad is locked, for unlocking simply tap twice on the orange light on touchpad, and it will start working again
Regards,
Bilal
I spent 45 minutes pushing the touch pad in random places fairly hard trying to make it work. It didn't work. Finally; while giving up, I read the directions to my 90 year old grandmother out loud and she said, "Maybe you have to touch it softly?" Duhhhhhhhhhhhhhhhh. It worked. I value her patience, because I was ready for WAR!!!! Thanks Bilah
Regard, S. Dave
Thank God for grandmothers! I was where you were at, but then I read your comment... Thanks again! Gunn, Norway
it didn't helped
Thanks grandmother......she solved my problem
I am so glad to have come across this wonderful advice! I too, was at my wits end when I read "Maybe you have to touch it softly?". Thank you for putting this on!
This issue was driving me crazy. The "soft" touch worked!
Turning the TouchPad on and off
The TouchPad is turned on at the factory. When the TouchPad zone is active, the light is off.
To turn the TouchPad on and off, quickly double-tap the TouchPad off indicator.
the indicator is on the top left side of TouchPad zone.
Good Luck
