The volume of samsung E250 is low and i wanted to know the secret codes to increase the volume
Press *#0206*8378# then choose second option then audio settings then mp3 speaker then rx volume then adjust it to how you want it
Press *#0206*8378# aftr this u have to choose h/w test aftr that audio setting & in the 13 option IIS NORMAL 2 go to rx volume & increase it level by level
ENTER *#0206*8378#
>>H/W TEST>>AUDIO SETTINGS>>IIS NORMAL 2>>CHANGE EAR GAIN TO 15>>THEN GO TO RX VOL>>then change to how loud you want it by each level. there are 14.
CAUTION:SONG QUALITY GOES **** IF PUT IT TO HIGH. WRITE EXISTING SETTING JUST IN CASE YOUR NOT PLEASED WITH IT. hope this helps :)
This could just be a setting in the phone. If you go to your menu and settings you will have a phone settings option. Just go to volume and turn it up to where you want it. But you should have volume control when on a call to so you can adjust it from there.
I tryd 1 of d codes nd my fones volume z damn so down nd i wonda what i waz doing
Code to restart 5130 expressmusic
The "secret code" for audio options is *#8999*8378# but before you use this you should know that when i tried to do so,my earpiece is now so low,that i can not even hear what the other person is saying.Use the code only if you know how to do so!
i need a code to increase the volume on my phone,so far,none have worked
hi i have e900 and i want the code for the volume to make it loud reply me back on [email protected] thank you.
the volume that im talking about is ,when i play music it slow and i need to increase it with special code and i need to know how would i do that and i have the code.
how to increase volume samsung s8300
