Most of the known "region free codes/hacks" are for stand alone DVD players. To my knowledge Samsung's (and for that matter most of the other brands) Home Theater Systems would "borrow" any one of their standalone players and use the engine/assembly as an integral part of the Home Theater System. Having said this then it would be necessary to know the original model number of the DVD engine player to be able to figure out the codes/hack. Additionally, most of the codes/hacks require the remote of the stand alone DVD player and not the remote of the Home Theater System.
Based on all of the above, perhaps your best bet would be to try all the known code/shacks (shotgun approach) But then again, the next problem is one can never be sure when it does not work since it could probably be due to the remote being used.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Samsung
HT-DM150, HT-DM550
Multi-Region:
Switch Off player and Unplug from mains wait 30 seconds
Reconnect to mains
Turn On player with remote
Press Enter on the remote
Press 8, 4, 2, 6 and 9 on the remote
The tray will Open and player will power Off and Close tray
Switch On power from remote
Player is now Region Free
You can change region code three times, I do not know if there is a hack to make it universal, I will have a look.
I got this procedure (thanks russ birks)
Give it a try.
"Here is the correct codes to change from Region 2 to Region Free:-
1. Open tray and remove any disks in tray.
2. Close tray.
1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
2. Reconnect to mains
3. Turn on player with remote.
4. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9. Using keys on remote.
6. Press ENTER on remote. (The tray will open and player will power off and close tray.)
7. Switch on power from remote.
8. Player is now Region Free.
Let me know if you need more help.
Well good to know, I will be grateful if you accept the solution.
the following worked for me on my Samsun HT-DB650
1. Open tray and remove any disks.
2. Close tray.
3. Switch Off Player and Unplug from mains - wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
7. Press 8, 4, 2, 6, 9. using keys on remote.
8. Press ENTER on remote. (the player will power off. If not, power off using the remote)
9. Switch on power using remote.
10. Player is now Region Free.
AA66
