Sierra Print Artist Platinum  Logo
Posted on Jan 12, 2011
With a Windows 7 operating system, what product can I find that would be comparable to the old Print Artist 8 Grande Suite? Has Nova come up with anything to compare (I've gotten more recent versions and am not impressed) or have other companies done better in matching this much beloved suite? Compatability is now an issue also. I just need names I can use for comparisons. Is Print Artist Platinum 23 similar enough in ease of use? Thanks for considering this. Joan V.
  • delile Sep 05, 2013
    yes it is print aritst platinum 23
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jan 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
1318
Points
11
Hi Joni703:
I would recomend running your old Print Artist 8 in compatability mode, since you are dissatisfied with the new programs. to do so, install the program on your windows 7 system, if you have not tried already, and right-click on the corresponding desktop shortcut. When a menu comes up, left-click on properties. at the top of the properties window, click on the compatability tab. Next, click on the check box labeled "run this program in compatability mode for:" and pick the system you have used Sierra Print Artist Platinum on previously. It should function normally.
Print Artist Gold. It will not load or start.
I looks like there are known issues
https://www.google.com/search?q=Print+Artist+Gold.+It+will+not+load+or+start
It says it works with Windows 10. but make sure you have the latest version 25.
System Requirements
Version 25 Platform Windows XP, Windows Vista 32-bit, Windows Vista 64-bit, Windows 7, Windows 7 64-bit, Windows 7 32-bit, Windows 10, Windows 11
  • Windows XP, Vista, 7, 8, 10, or 11
  • 512 MB RAM
  • 1024 x 768 display or higher
  • Internet connection required
  • Recordable or rewriteable CD drive required to burn CD slideshows
My Print artist has stopped working. The Cd rom in my PC is broken so I can't reinstall. What can I do
Print Artist Platinum 24 has stopped working - Fixya
www.fixya.com/.../t13886156-print_artist_platinum_24_stopped_worki...
Aug 4, 2012 - either right click on the setup program and select run as administrator or log in using an administrator account on your PC to install.
Amazon.com: Customer Reviews: Print Artist Platinum 25
www.amazon.com/Nova...US.../B00EPACO3M
Amazon.com, Inc.Find helpful customer reviews and review ratings for Print Artist Platinum 25 at ... Installed this piece of garbage a week ago to start working on a project for a major .... Software performs quite well once the learning stage has been passed.
Support : Nova Development Technical Support
support.novadevelopment.com/
I have a version of Print Artist that came out before version 21. ... When working in the program, it freezes and shows a message "Not Responding" message at the top of ... When exporting a project as a SketchUp file, it has unwanted triangles.
Print Artist Gold 25
Error 1935 while trying to install Print Artist 25
Unlimiting the registry size could work:
Here are the steps:
1) Type REGEDIT in run
2) Navigate accurately to:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
3) On the right pane, locate the following
Key: RegistrySizeLimit [Type: REG_DWORD]
4) Double-click on it.
5) On the dialog box, select DECIMAL radio-button
6) Erase the previous and enter the following number:
4294967295
7) Again select, HEXADECIMAL radio-button
8) Click okay and restart computer
9) Everything will be okay, ENJOY! try to install the package again.
[email protected]
Is Print Artist Platinum Edition version 22 compatible wit Window7?
Print Artist Platinum Edition version 22 is compatible with Win 7.(x86 X64)
You can check this @ Windows 7 Compatibility Center
Hope it helps.
I just bought the "Print
Did you get the win 7 version, if so the disc may be faulty . get the vendor to check it
2answers
I have upgraded from XP professional to widows 7 now I cannot install my Print Artist grande suite. please help Lorraine
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties.
Select Compatibility tab and select the Windows XP version.
This should work but if it doesn't there is nothing you can do except complain to Sierra to make a fix for it.
goodluck
Want to transfer Print Artist 4.0 Platinum by Sierra from old computer using Windows XP to new computer using Windows 7. Each effort results in a window appearing which states "Run-time error "5".
This simply means that your Print Artist program is no longer compatible with Windows 7. Some of the support files that used to work with XP is no longer recognized in Windows 7.
One way to resolve this is to contact or visit Print Artist's developer's website and search or ask for any windows 7 support or patches for your version 4.0
Top Sierra Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Are you a Sierra Computer and Internet Expert? Answer questions, earn points and help others
