Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
IPOD 20GB CLASSIC
AFTER A WEEK OF NON USE I TRIED MY IPOD BUT WAS COMPLETELY DEAD. I HAVE TRIED TO CHARGE IT STILL NOTHING. SHALL I BIN IT AND GET ANOTHER OR CAN I BRING IT BACK TO LIFE?
THANK YOU
DAVID S
  • 1 more comment
  • Anonymous Aug 07, 2008
    THANK YOU.
  • brendanp93 Dec 10, 2008
    Sometimes my Ipod will just not work or show any sign of working, every once in a while Ill get a frowny-face ipod with a caution sign or just the apple logo.  Ive found sometimes it will work after a few weeks of just sitting there, but If I can fix it or at least know the problem that would be great
  • lizkberger Dec 29, 2008
    =[ mine too
  • 342 Answers
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
http://fixyouripod.weebly.com
Posted on May 19, 2009
SOURCE:
Apple 20gb ipod classic it shows a plug in wall image what do i do
Charge it !
You can charge it by pluging into the computer if you dont have a charger.
Leave it in for 4- 8 hours.
Jun 07, 2011 | Apple 20gb Ipod Mp3 Player With Click...
Ipod classic 20GB not getting on.
This is sometimes the case with old ipods. Hold down the power and center button together for 10 seconds. If still it does not boot up the charge it using a wall charger (not USB from computer) and do it again. It will be solved 100%
Mar 03, 2011 | Computers & Internet
Ipod ''dead''
Plug your iPod into a wall charger, let it lie for a couple of hours. When these batteries become completely flat, it won't easily charge through computer usb, so try the wall charger, see if it works.
Nov 17, 2009 | Apple iPod 4th Generation MP3 Player
I have a silver ipod classic 16GB, and it was my cousins but he rencently got an iPhone so gave his classic to me. Im not sure how long he has had it for but when i started using it the first time i...
Yes, This problem is generated by battery. If Battery is dead iPod Could not start.
Contact Nearest apple care center & replace Battery of your iPod & i will start.
I am very happy to assist you.
Thanks.
Oct 10, 2009 | Apple iPod classic MP3 Player
Bose SoundDock burned out two of my iPods - a Nano and a classic.
um ur sounddock might require that u place the white docking piece that came with ur ipod to be place b4 the ipod is docked if not u may ruin the dock and the ipod usb port this is done because different generation ipods(nana and touch and ...) have different shapes so the entrance for docks may require to be eleveated or reduce in gradient basically if the dock isnt made for the specific ipod or u dont know just put the white piece in
Oct 04, 2009 | Bose SoundDock digital music system...
IPOD SAY WWW.APPLE SUPPORT
It may need a firmware update, or the battery is bad. Try their site, I had success w/one of my ipod's with the same problem, now it works fine. Hope this helps.
Aug 17, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Ipod not charging
Does it turn on when it is plugged in? If may be a bad battery. Sometimes when a LiOn battery goes completely dead and is left for an extended period of time, it will not accept charge. If it is under warranty, contact Apple support and have the battery replaced.
Cheers
Jan 03, 2009 | Apple iPod classic MP3 Player
How can I power on and power off my apple ipod a1136 model?
Generally speaking, if you have connected it to a power source when it has completly drained it should display 'Please Wait, Very Low Battery' (without the backlight). If it does, leave it until that message disappears. Pressing the play button should now wake it. However, If you have been charging it for a while and nothing has been displayed the battery my be dead all together. With the iPod connected press the Select and Menu Buttons together until an Apple symbol appears (non-backlit) it should then startup. If it turns off when disconnected from the power then you have a dead battery. If none of that solve it I offer a repair service at a very low cost.
Dec 13, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod classic 80gb
Have you tried plugging your ipod into your PC to see if that kicks it into life?
Jun 02, 2008 | Apple iPod classic MP3 Player
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
407 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Jeffrey Groves
Jeffrey Groves
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
