1994 Mercedes-Benz S-Class Logo
Posted on Jul 13, 2008
Mercedes S320 central lock
Hi, I've got a 1995 Mercedes S 320, and my central lock work only from the switch inside the car, and when I press the key button nothing happened.
Can you please help me?
Thanks
  • 5 more comments
  • Anonymous Dec 28, 2008
    doors will not lock trunk will not lock rear markers will not come up when put into reverse and gas cover will not lock all on same system or what?
  • pattykiddy Dec 31, 2008
    Send previous information to correspondence to PattyKiddy!hotmail.com
  • Anonymous Mar 18, 2014
    My Mercedes e240 2001 model parking lights turn on when i lock the doors with the remote key. Please advice what could be triggering this. Thanks
  • Anonymous Mar 23, 2014
    When central locking button pressed, both green and red light flash but side light does not make noise
  • Anonymous Mar 24, 2014
    my smart key is not going inside the power switch and steering is not being lock
  • Anonymous Mar 28, 2014
    The door buttons go down and straight up, can only lock via trunk or key in passenger door
  • Anonymous Mar 31, 2014
    car is not shifting into 2nd gear,is this "limp mode"?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3276
Points
My key got very very wet can you help
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3699
Points
If you hav a remote control key &yr car wont respond . change key batrrey &contact dealer if still dont work for software
Anonymous
Level 1:
  • Contributor 19 Answers
  • Posted on Nov 13, 2008
Anonymous
Contributor
Level 1:
Answers
19
Questions
Helped
26530
Points
97
The Key Fob needs to be syncronised to the car........Try this it works for many Mercs1....ensure the battery in the "Key Fob" is OK............Press either Lock or Unlock button for more than 1 second, the lamp on the fob will light if OK. Change battery if it does not illuminate!  2.....if battery on fob OK.......Re Syncronise the key fob to the car by:.... a brief press on either button twice and within 30 seconds turn Key to position 2 on the ignition lock
Hope that fixes it...let me know?
Why wont my 1997 mercedes S320 start ?
What happens when you turn the key? Do the door locks work? Do the headlights work? Once I get that info I can help point you in the right direction
2helpful
My s class 2004 mercedes wont lock. I try to lock it from the inside, it doesn't work. I press the remote, the light flashes, but it doesn't lock. When I drive; the doors doesn't lock like usual. The...
hi, if any doors, boot or bonnet is open it will not lock. there are SWITCHES that has to be set.for the system to recognize it is closed. please check all openings even windows. ONLY DO THIS IF.if the BATTERY HAS BEEN TAKEN OFF OR BATTERY HAS BEEN DISCONNECTED. the SYSTEM MAY NEED RESETTING. the battery NEGATIVE lead needs to be taken OFF and place the NEGATIVE LEAD ON THE TERMINAL (A NOISE WILL BE HEARD), the ALARM and CENTRAL LOCKING SHOULD BE RESET, if the ALARM DO'NT SOUND put the lead ON and OFF a FEW TIMES. CLAMP THE BATTERY LEAD CONNECTION TIGHT and press the ALARM BUTTON OFF and retry locking SYSTEM. this will work if everything is O. K. gerry
2helpful
MERCEDES S320 model 1999, key locked in the Trunk.
Isn't there botton somewere on the door or left lower conner of dashboard to open trank remotely?
1helpful
On 1994 mercedes benz s320 central locking will not work by key or dash switchhave checked the fuses i can find,when door key is turned pump under rear seat works for about 10 seconds any clues where to...
The locking system is controlled by vacuum . It is really hard to figure out because there are so many things that need to be checked. You can look for broken vacuum hose under the hood. Or under the dash. There are vacuum controls in the doors. Theres a vacuum canister in the trunk. Good luck This may help some. Leave comment.
2helpful
Central locking on key not working, have replaced batteries and reset the key which did work, but key still not working. Can lock car from middle console and manually lock driver's door. Any ideas. Thanks
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Programming
When
Key remote control added or replaced. System malfunction.
How
Keys can only be programmed using diagnostic equipment.
NOTE this only works on ml up to 05
1995 Mercedes Benz S320
sounds like you have a wiring problem in the main lock switch in the driver side door or wires that run from there to the other doors. one of the wires in this system does not have a good enough connection to allow enough current to operate the locks. put another way, the wire itself is introducing unwanted resistance which reduces the current flow. the resistance could be a result of a poor connection at a junction or a section of wire which has corrosion or some other problem which diminishes flow. to find exactly where the problem lies will involve removing door inner panels and making voltage drop tests across connections. works something like this: i started out with 12v dc, i know this component should use 3.4 v (or whatever it is) but now i only have 4 v coming to this next component. so the wire is using some of the voltage. some drop in the wire is normal, but not very much. that is how i would troubleshoot it. you can just check the connections to power and ground, just look at things and make sure you don't see corrosion, wiggle connections and see if it makes something different happen, but you will still have to take the doors apart to do it. hope that helps
2helpful
Key problem
You`ve obviously got two problems with ur vehicle,
You need to get a diagnostic readout on the various systems which are being displayed on ur dashboard. If youve been disconnecting the battery, these lights will appear because the steering angle sensor will need setting.
The fact that ur key dont turn could be a few things
Firstly the key, have you got a spare to try? If u havent then get one
Secondly It could be the EIS switch itself, I change loads!
Good luck!!
Carlo@SS
13helpful
2answers
I have a 1995 Mercedes Benz s320 and my doors wont lock
There is a central door locking pump under the back seat, the motor has gone in it, cheap way to repair is to strip it down and put a motor in it from a tyre compreser from argos for under £10 very easy to fit just two wires
4helpful
3answers
How to reprogram 1999 mercedes s320 key remote?
just insert the key to the ignition swich and leave it for one minute, it will work for sure.
Adel
22helpful
3answers
Peugeot 307 1.6 petrol central locking problem
leave ign off with key out 3mins disconnet battery 5 mins reconnett and press lock/ unlock repeatedly until locks cycle through to re sync try this any probs come back to me
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
