Microwave Ovens Logo
A
Anonymous Posted on Jan 11, 2011
I'm trying to find a replacement glass tray for my Amana microwave oven. The model number is RRL-10TD. The date on the back of the oven is 1982.
Anonymous
Level 3:
  • Amana Master 43,501 Answers
  • Posted on Jan 11, 2011
Anonymous
Amana Master
Level 3:
Answers
43501
Questions
0
Helped
10835241
Points
101584
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Need new glass tray for Kenmore microwave bought in 1977. Model # 99371.
They made Microwaves in 1977? wow. I would try an appliance junkyard, or ebay. We have used a microwave safe plate of the right size and it worked well. Good luck!
Turntable on Amana microwave does not turn anymore.
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $35 to $45. The coupler is less than $10. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
WE need a replacement glass tray
If the model number is correct, the glass carousel tray is available at repairclinic.com for about $30. The item number is 1206676. I hope this helps you.
1helpful
When the glass tray turns it makes a noise. When
This problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to (and is located under) the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray that you were referring to. The following link explains how to access and replace one:
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. If the model number is correct, the part number for a replacement motor is WB26X10135.
If you have any questions, please post back and let me know. I hope this helps you.
GE spacemaker UMV1152AAW. Where can I find a glass cooking tray?
The model number belongs to an Amana brand microwave.
Here's the link to the tray for that model...
www.microwaveglasstrays.com
Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
1helpful
Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Glass tray is broken
If yours is a Magic Chef model MDC1311ST, then your part number is 3517207600 and you can order it here.
Otherwise, please reply back with your brand and model number so we can help you.
2helpful
I have an Amana Radarange Microwave Oven Model #44-9 that I purchased in 1976. Accidentally I used the microwave instead of the timer for 30 minutes and about 25 minutes into the cooking I heard a pop. ...
Is that model number RR-9?
You can find and order that part (# AP118264) here.
I just hope your magnetron is not blown, too. (Does it still heat?)
You can use a microwave-safe plate in the meantime.
Top Amana Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
