The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
You can do this by: Check the oven display to see whether the
screen says "LOC." When "LOC" is displayed, the oven lock is activated
and the door cannot be opened. You need to make sure it is locked so you
do not mistakenly lock the door.
Press and hold the "Stop" button on the oven control panel
until "LOC" disappears from the display. Some oven models have a button
marked "Oven Lock," which should be used instead of the "Stop" button.
Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
Thanks for posting to Fixya I will be helping you today. You have posted that you have a Kenmore Elite 44173 electric cooktop with a problem. However, you also mention your are having trouble with the oven not working. This post maybe categorized wrong but I will try to answer you question for both a range and oven control.
Sometimes on a cooktop customers will lockout the controls on accident while cleaning. Usually there is a button on the control that you hold for 4 seconds +/- and there is a little simbol of a padlock next to it or you might have to check the owners manual.
Lastly, Ranges may also have a lock out feature that the customer must press 4 seconds too unlock. On select models controls may also be locked out by putting their oven into sabbath mode. Usually the display will indicate a "SAB" to alert that this feature has been set.
*In general the above instructions should help if your unit is locked out.
Happy Holidays! "Please rate this information "4 thumbs" if you found informational.
I believe that if you look on the name plate for the unit , it says that you will need a 30 amp, 220 volt supply circuit . This would be a two pole , 30 amp breaker , a run of # 10-3 cable with ground, and a junction box at the stove top location to make the splices. If you are going to use a plug connection, then a 30 amp 4 wire dryer outlet will give you the connection you need .
