HTC Touch Cruise Smartphone Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I canot conect with my pc. - HTC Touch Cruise Smartphone
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Jan 11, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470097
Points
19564
Install the HTC driver on your pc then paired them using firewire
How i can connect my samsung netbook N210 with panasonic TH42PA20 tv by vga cable
if notebook got vga out and tv got vga is verry simply, conect them and after select tv as your secondary display
cole primary display to the seconday
start tv and go to the imput menu, select pc
and will be ok
just 1 problem the clarity of vga canot be compared whit hdmi conection
best regards
12helpful
I am unable to connect my samsung B5722 handset to my PC for using the internet service.What is the reason?
i m honey sir i use samsung b5722 my problum that i canot creat the set up of conection with pc plz tell m solution...
2answers
Sanyo 4370 canot start code10
Your GPS battery is dried out, use the original car charger or one that can output at least 1.5 Amp.
1helpful
Wifi signal canot conect because of DNS problem
see pal.for this you do require ip address settings by that i mean ip address,subnet mask and default gateway.if you do have these settings then the dns address can be used for static ip address primary = 4.2.2.2 & secondary = 4.2.2.3
take care
Canot conect wirelessly
Hi.
you can obtain an Aol installation disc from PC World. This will take you through the installation procedure.
I canot conect wirelessly to my netgear dg834g wireless modem router
ok! i think i got it! run the setup wizard that comes with the router. follow it step by step, and then push the "push -n- connect button on the router, the router does the rest itself. assuming you have the dsl line plugged into the router.
2answers
How to troubleshooting internet issues
Basically means you aren't getting any DNS service.. Check your IP settings
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
