SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
SOURCE: Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
SOURCE: How to check the MAC address of Zebra 105SL Printer
go to the configuration on the printer. Scroll through until you reach the network settings. You can display or print the results, which will show the MAC address. Also, if you have a PC on the same network, and you know the IP of the printer, you can look at your ARP tables and find the MAC associated with the IP. ARP -a at the dos prompt
SOURCE: Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
SOURCE: Zebra 105sl felt paper error
check if the sensors behind the printhead (small metal open case)is on the same position that the uper sensor(black plastic bit with the screw behind the printhead) Run the sensor profile, check if he check the gap.
run manual calibration from the settings.
worst case senario, Reset the printer to Factory defult (Press PAUSE and CANCEL buttons and tun printer on, then relese the butons after 5 secounds.
