Your mixer is already grounded, and does not need any additional grounding. It is grounded through the Power Cord.
Now, the feedback might be coming from one of the units you have connected to the mixer. The issue could also be the cable you are connecting to your recorder. Are you recording to a computer, or to some other external recorder (CDR / DVR / MDR, etc?) - try a different cable. Also try the different outputs on the mixer - you have 2 balanced line outputs you can record directly from. Don't use the RECORD OUT line, it's an unbalanced line, and if you want a good quality signal to record, your best bet is to use the XLR outputs. However, that might be connected to your amp or something.
What do you have going to the unit? Disconnect everything, and try by connecting each item 1 by 1, to eliminate where this feedback is coming from. Also, check for any ground loops that you might have, if you have a lot of equipment hooked up in your set up. (
Educate yourself on Ground Loops)
If all else fails, get yourself a HUM ELIMINATOR.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
