SOURCE: soaking wet clothes
Harm, remove the lower panel and you will see the filter right in front. Unscrew the filter strainer and clean all the lint and debris. This machine has a pressure switch that won't allow a high spin if it detects water in the tub. Therefore you get these pauses and slow tumlbe. Try this and see if it's normal after cleaning the filter...Catriver...post back
SOURCE: washer doesn,t spin
Looks like chat support session must have timed out. The answer to your last question was, yes, pres. analog switch with a red, a white, and a blue wire to it.
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
SOURCE: My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
