Question about Casio Office Equipment & Supplies
Ink absober is full - Casio Office Equipment & Supplies
  • Casio Master
  • 3,267 Answers
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Posted on Jan 11, 2011
    New Friend:
My Canon 3680 Photo Printer in Giving Yellow Signal in Resume Button
Posted on Jun 02, 2012
4 Suggested Answers
SOURCE:
  • 1550 Answers
SOURCE: How do I fix or reset ink absober full problem on
Reset procedure
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
Posted on Mar 13, 2009
  • 14 Answers
SOURCE: Error code E27
take out long black sponge under print head. wash, dry, replace.
Posted on Apr 20, 2009
arjoon
  • 113 Answers
SOURCE: absober waste ink is full. Pls help. error code
you need to replace the absorber waste ink pad and service the printer
Posted on Nov 17, 2009
Testimonial: "Thank you. Looks like it is not a DIY job."
How do i fix ip 4940 printer ink absober full problem
Open the printer carefuly remove the ink absober located under the head cleaning mechanism, wash it with water and liquid soap, dry it and re use againg. If you have new absober just replace.
Jan 11, 2015 | Office Equipment & Supplies
My canon ip7240 is saying ink absober full how can i reset it ?
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. ...
  4. Keep the Power button held down. ...
  5. Release the Power button.
More items...
Reset Canon Printer ink absorber ' Fix-KB
www.fixkb.com/2011/06/reset-canon-printer-ink-absorber.html canon ip7240 is saying ink absober full how can reset it Google Search
see if this helps you out.
Apr 15, 2013 | Canon PIXMA MP170 All-In-One InkJet...
Ink absorber almost full
Need to reset waste ink absober full.
Follow this step to reset waste ink absober full.
1> download iptool to reset waste ink absober full
Download here ----> Service tool 1
Service tool 2
After ypur download finish
> turn off your printer power switch
> open your printer cartridge door
> press and hold on/off button (never release)
> turn on printer power switch
> push your printer cartridge door switch with pen or anything can press door swith.
> then release on/off button
> close open door
> then press on/off button 1 more
now your printer is in normal mode( no orange led blinking)
Then you can use ip service tool to permanent reset waste ink absober full.
Hope this guide can help fix your problems
Extra download
Fixwasteinkabsoberflowip1000
Jul 20, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
There is a message that ink absorber is full and contact tne service centre.
Service tool 2
> close open door
Extra download
Fixwasteinkoverflowip1000
Jul 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My canon ip1980 appears error 5100 on my display i will replace my data strip but the problem still occurs. What should i do. Tnx
This problem is between waste ink absober full and ink cartridge.
Firstly your need to reset waste ink absober full.
Service tool 2
> push your printer cartridge door switch with pen or anything can press that door swith.
> close open door
IF after reset your waste ink absober full, problems still apppear error5100
> change your ink cartridge with the working cartridge
usually error e5100 due tow problems above
Extra download
Jun 23, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Absober waste ink is full. Pls help. error code
Nov 17, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The waste ink absober is full. If a service
You really need a service center for that, some have posted methods to reset here, but when the ink overflows it ruins the printer, and anything it leaks on.Canon customer service can tell you the nearest center. 1-800-828-4040.
Oct 09, 2009 | Canon PIXMA iP90 Mobile Printer
Ink absober is full error 2 and 7 canon MP 160
it looks like you will need to take to a service center to get it replaced. You probably have used your machine a lot and the waste pads are full.
Apr 17, 2009 | Office Equipment & Supplies
1,497 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
