SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
SOURCE: range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
SOURCE: Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Hello &
Welcome to FixYa
Error F9-5 in
your Maytage Gemini means Latch unlock lower and is displayed due to
obstruction in door lock mechanism. If after cleaning the door lock mechanism
the problem is still there then replacing the door lock mechanism is
recommended repair. Please get back to me if you have any other questions.
Kevin
F9-2 error code indicates:
