IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
If you are using the fx/send port to the mic-in port (I have no idea why you would want to do that) but nevertheless, check the red fx dial and make sure it is at 12 oclock and turn the pan dial to 12 oclock also. remember if you are using mic input 1 or 2 with a mic that requires Phantom power the button needs to be locked in the down position. OK im assuming you have checked and set your gain and volume levels on the 802 prior to plugging in your mic. If not do so now.(unplug all outputs and with mic plugged in speak into the mic while turning up gain until you get distortion which is indicated by a rewd light next to the "pan" button...once you see that light turn the gain dial back slightly and you should be set) have volume at 12 oclock on both l"evel1" and "main mix: dials. Now goto your windows desktop and right click on your volume control "speaker" icon. Click on "Playback device" you should see your mic in the list on enabled devices.If you dont see your mic in list right click the screen and click show disabled devices. Enable your device. If it is already enabled right click it and make sure it is not muted. finally go back to list of playback devices and right click your mic and click "configure speakers" run through the tests. close everything.mic should be working now. If it is not I suggest you plug your mic into either the line in from the fx/send or keep it in the mic-in port and plug the other end into the head phones port.Or better yet, get an rca to mini stereo jack and use the cd/tape out jacks to send your signal to the mic port of your computer......keep playing with it...you'll figure it out.There are so many different ways to hook up your perephrials its mind numbing sometimes.
There is not enough information to go on here. A condenser mic is usually connected via XLR connections and receivers done have thaty type of input. Where is the phantom power coming from. Perhaps the wiring of hte XLR is incorrect for the equipment being used. (There are 2 standard connection styles). Can you update this with the equipment being used and how it is connected?
Your microphone has a stereo miniplug, with 3 contacts, that look exactly like headphone minijacks. You have not stated where you are trying to plug this microphone, but most computers /sound cards will accept only mono minijacks, with 2 contacts. Should you have left/ right inputs for microphones, buy a splitter adapter that will turn the stereo jack of the microphone into two mono jacks.
I noticed that Avaya headset is different from the Avaya handset or any other standard headset: The outer two pins are switched.
Avaya-Headset-pinning is like this: Look to the RJ11 and turn it until you see leads from top and from front, then from left to right you look at 1) mic 5V 2) speak 3) speak 4) mic gnd
RJ11 of Avaya-handset and any standard headset/handset from the supermarket: 1) mic gnd 2) speak 3) speak 4) mic 5V
If your mics are XLR (a hole on the bottom of the mic with three pins visible in it) you will need one of these for each mic, plugged into one of the four channels on the tascam that has an XLR connection (which will be the female version of the connection on the bottom of your mic). If your mics have a 1/4-inch connection, you can use the 1/4-inch connection on any channel on the tascam. For the stereo connection, you will need one of these of sufficient length to convert the RCA output from your stereo to the 1/4-inch input on your Tascam. Find "Tape Out" or "AUX Out" on your stereo and plug in the RCA side of the cable there (note which color you use for R and L). Use the 1/4" end of the cable to connect to two available channels on your mixer. Use the Pan knob to pan the left channel to the left and the right channel to the right, and voila! Hope this helps, and good luck!
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors. Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14 1 ... .. ... 13
The pinouts are:
1 Mic in/center 2 Ground 3 Mic power/Bass 4 Audio power 5 Right line out/Speaker out Right 6 Right line out/Speaker out Right 7 Reserved 8 Key 9 Left line out/Speaker out Left 10 Left line out/Speaker out Left 11 Right line in/Rear speaker Right 12 Right line in/Rear speaker Right 13 Left line in/Rear speaker Left 14 Left line in/Rear speaker Left
All of three of these components have balanced connections. There are many different ways to connect- but this is the best option. You will need 4 x standard XLR3(cannon) mic leads. Starting from the Gemini mixer:
take the left output and plug it into channel 1(A) of the DOD EQ
take the right output and plug it into channel 2(B) of the DOD EQ
then...
Connect the EQ output of channel 1(A) to the input 1(A) of your Carvin amplifier
Connect the EQ output of channel 2(B) to the input of 2(B) of your Carvin Amplifier
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo.
Maybe you need a stereo mini. Usually a cable mismatch is the problem.
Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two.
Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel?
I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Stereo requires two different inputs, as the very name implies. If you're using just one mic, it is possible to "pan" that input to both left and right, but is not truly stereo. For true stereo, you must have at least 2 mics, or 2 or more of any other sources...accordianman
