SOURCE: washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
