SOURCE: Weeping Demon pedal broke
Suspect that the circuit board may have cracked in the vicinity of the power jack. Also check for a switch under the pedal. SOme have them and it might be broken.
SOURCE: when i select the wah pedal funtion, it does not make the wah
You are apparently talking about an FX pedal with a built in wah function. Which pedal and model number? The Digitech RP350 for instance has a special procedure for initializing and recalibrating the pedal. Is that the problem or is it maybe the opto isolator ?
SOURCE: Wha pedal dysfunctioning
Its cause from an intamitent in other words a make and break in the pedal.
