Hi I have a Hotpoint WMA63 washing machine. The belt kept coming off so I bought a new one. It was smaller as the old one was loose. Problem is that it still keeps coming off. Can anyone help?Hi I have a Hotpoint WMA63 washing machine. The belt kept coming off so I bought a new one. It was smaller as the old one was loose. Problem is that it still keeps coming off. Can anyone help?
You can't post conmments that contain an email address.
If your Maytag washing machine is agitating during the spin cycle, it could be due to a few different issues. Here are some possible causes:
Defective Transmission: The transmission in the washing machine is responsible for shifting the agitator and the drum between the spin and agitation cycles. If the transmission is defective, it may not be able to engage or disengage the agitator properly, causing it to spin during the spin cycle.
Worn Drive Belt: The drive belt connects the motor to the transmission and helps to control the speed and direction of the agitator and drum. If the belt is worn or damaged, it may not be able to properly control the agitator, causing it to spin during the spin cycle.
Malfunctioning Clutch: The clutch in the washing machine helps to regulate the spin and agitation cycles. If the clutch is not functioning properly, it may not be able to disengage the agitator during the spin cycle, causing it to spin along with the drum.
Faulty Timer: The timer controls the various cycles and functions of the washing machine, including the spin and agitation cycles. If the timer is faulty, it may not be able to properly sequence the cycles, causing the agitator to spin during the spin cycle.
It's best to have a professional technician inspect and diagnose the issue to determine the exact cause and the necessary repairs.
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
From the information you have provided water will fill, drain and spin but your Frigidaire washer is not agitating. This could be a problem with your motor, belt, or pulley. Locating the problem is not a simple DIY job and I would suggest seeking assistance from a professional. They have the appropriate tools needed to disassemble your washer and prevent any future issues. I hope this information is helpful to some degree. -Matt
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Either the belt or you transmission could be slipping and it making the belt work harder on a full load. Try running the spin cycle without water to see if you hear it. If you do then it is the belt, but if you only hear with water then it is your transmission.
Spider arm to the washer drum is broken. Parts is expensive and labor to repairs will cost you more than if you just go out and buy a new washer. Sorry for the bad news.
I have a related problem and I just learned on the net that the Vbelt is supposed to slip in "idle" mode while the water pump will do more work. It is also supposed to slip slightly while speeding the spinning up so as to not cause motor overload.A kind of half clutch function that allows for slipping. This slipping is controlled by the tensioner.
My guess is that your machine's v belt slips too much and thus does not spin fast enough. You replaced the belts, I would look at the tensioner now.
