The best thing you can do is call Lutron's tech support at 1-800-523-9466. They're available 24/7 and get probably point you in a better direction than being able to diagnose / troubleshoot over e-mail / this forum. Generally speaking, I don't think they will replace your plastics. It is possible for it to get worn over time - but that could be the plastic, or it could be the buttons within the unit. Either way, like I said, they probably won't recommend anything to repair the unit, but you can request that they replce it - especially if its only been in use for 3-5 years.
My dimmer went on the fritz...after reading the above I called the 800# and got tob the tech guy for homeowners. Stated my case....he had me read the #'s on the bottom in the metal....mine was S18....he said it was made in 2009....thewre was a pause at both ends then he said he'd replace it. Great guy as it should be....
Thanks for this site you saved me mucho dinero
frank malone
california
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
