Computers & Internet Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set up router/modem as instructed but http 192 168 does not respond
Tai Viinikka
Level 2:
  • Expert 22 Answers
  • Posted on Jan 10, 2011
Tai  Viinikka
Expert
Level 2:
Answers
22
Questions
0
Helped
13482
Points
103
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
2answers
Changed modem need to reconnect wireless router
Changing routers can be a hassle, especially if all wireless connections are in-sync with the old one. The basic steps below in setting-up a wireless connection applies to all brands of routers. Most softwares provided by manufacturers, both computers and routers, cause problems with Windows due to incompatibility issues. We will use the Wireless Zero Configuration or the Windows Wireless Manager that comes with all versions of Windows to put ease in setting up your Linksys WRT160N.
Click the link below for proper cable connections in setting up your wireless network. It also provides somewhat a checklist on what you need for wireless connectivity.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
1helpful
Sir The belkin wireless router is not responding in BSNL PPOE broadband connection what is the way to get connected through the ISP of BSNL. murali
IF u are using the BSNL broadband connection, you might be having a modem provided by the BSNL, 7230 model is only a router, it doesnt have modem option so all u have to do is
1. Go to belkin page 192.168.2.1(if u changed the ip address in router, then type the default gateway of the router)
2. Click on connection type
3. Setup as a dynamic connection since the PPPoE is already set on the modem
4. Follow the on-screen instructions
5. Check the internet status, if its still showing as not connected then powercycle the router for 15 sec and then reconnect the cable
Hope it will work
No instructions
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Set up assistance instructions for Belkin N Wireless Modem Router
This is the Belkin site for your model with instruction set on the page link below:
http://www.belkin.com/au/support/product/?lid=ena&pid=F5D8633au4A&scid=845
1helpful
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
1helpful
Problem replacing modem/router
2helpful
2answers
How do you hook up a lilnksys router after you have tried everything, including going over the instruction manual and the cd setup?
To configure the wireless router, connect a LAN cable from the router to your computer, open a browser and type in the router's configuration URL IP address. http://192.168.1.1
login = admin
PW = blank (just press Enter)
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
2answers
How to hook up linksys wireless router
Since I don't know what type of router you have, you can go to this link and get step-by-step instructions for setting it up:
http://www.linksysbycisco.com/US/en/support
2answers
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Grand Canyon Tech
Grand Canyon Tech
