Disney DTD1363-CAR 13" TV/DVD Logo
Posted on Jul 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Service mode i need to get into the service mode in order to ghange the sound system
Anonymous
Level 3:
Genius:
  • Master 1,665 Answers
  • Posted on Jul 13, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1665
Questions
Helped
978905
Points
3981
1helpful
Alarm in my 2002 gmc Sonoma goes off when I open the door with the key. Lost remote. Can I disable the alarm without messing other things up?
Door Key Switch
The BCM monitors the door key switches in order to disarm the CTD system. When the lock cylinder turns in order to unlock the door, the switch grounds the disarm input to the BCM.
The key lock input to the BCM is probably missing , BCM doesn't see it . So it think's your breaking into the vehicle. Did you try the passenger door to see if it will disable the alarm .
The BCM - body control module ! Electronic -computer !
Content Theft Deterrent (CTD) Does Not Disarm with Key Lock
The factory service repair manual has a 23 step diagnostic procedure . An you would need a factory scan tool to find the correct fix.
Turn ON the ignition with the engine OFF.
With a scan tool, observe the door key switch parameter in the Body Control Module (BCM) security data list.
Does the scan tool display INACTIVE?
Locking the Vehicle Without Arming the System
Use one of the following procedures in order to lock the vehicle without arming the system:
• Procedure A -- Lock the vehicle using the manual door lock knobs. Close all the doors.
• Procedure B -- Close all the doors. Use the key or the power door lock switch in order to lock the door. The doors must be closed prior to locking the doors for this procedure.
Disarming the System
In the arm initiated mode, the following conditions are true:
• The security telltale is ON.
• The doors are open.
In order to disarm a system in the arm initiated mode, perform one of the following procedures:
• Press the power door lock switch to the UNLOCK position.
• Press the door unlock button on the key fob.
In order to disarm a system in the arm delay or the armed mode, perform one of the following procedures:
• Use the key in order to unlock one of the doors.
Deactivating the Alarm
In the alarm mode, the following conditions are true:
• The horns sound intermittently.
• The headlights and the park lamps are flashing.
In order to deactivate a system in the alarm mode, perform one of the following procedures:
• If the vehicle control module (VCM)/powertrain control module (PCM) receives a valid Passlock™ ignition key rotation.
Toyota rav 4 won t start when it rains
Sounds electrical. Either the distributer xap is crackes or plug wires need ghanging. Turn the key when it is raining and have a friend listen for a "snap" sound or look closely for arcing from the cap and wires. Autu stores sell a spray that dries out the wires, you may want to try that
1helpful
Problem in turning on the konica C452
check the power on logic on controlling board if not found change e prom
Make google my home page
hi
higher right bottom click then choice setting then second order (get themes the ghang the home page
Fit new battery try to start no power to statermotor.bypas relay statermotor run but enjine dos not start
Hi if it ran ok before you battery was ghanged it could well be your imobaliser there is a set way of ghanging the battery you may need to disconnect the battery & follow a procedure regads mick
I tryin to ghange the rods in my ford fiesta car
IF YOU JUST NEED TO FOLD THE SEAT DOWN LOOK UNDER THE BACK OF THE BACK SUPPORT, YOU SHOULD SEE A CABLE ( BLACK) PULLING THIS WILL RELEASE THE CATCH TO FOLD THE SEAT FORWARDS
My laptop went into lockdown mode and i dont know how to restore it so how do i restore the laptop and ghange the password
u go in user and then your laptop will start after then u change your password in security setting
I changed the fusing unit but its still say replace fusing unit
press clearmodes 107 and hold down clesr/stop until screen ghanges to sp modes then turn off and on using side or front on off switch and it will reset
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
