SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
SOURCE: Hi,Ihave a hoover hnf 7167
hi
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
SOURCE: I have a 12 year old whirlpool washing machine model lxr7144eq0
To determine if the transmission caused the belt to wear, then unplug the washer, and looking up inside toward the transmission, note the large diameter pulley that the belt goes around. See if you can turn it by hand. It should turn freely in both directions.
This isn't a 100% guarantee that the transmission is good, but will give you an indication. Make sure the washer is at the end of it's cycle when trying this.
If it turns, replace the belt and see what happens. If it doesn't, make sure none of the solenoids are engaging the linkage, otherwise, you'll be trying to turn the drum or agitator.
SOURCE: Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
