We have E200 razor electric scooter. it shows battery full when we remove charge plug. However, when we try to run it .. it's right way low better and does not go in speed.
The green light will come on if the charger does not sense a low battery. In other words, if you plug it into the wall, and not the scooter, it will still show the green light. It will only show a low charge (and charge the battery) if it is completely connected completing the circuit. My guess is that the battery is dead, and the plug is not all the way connected. Also, I believe the scooter has to be turned off to charge.
Charge the batteries. If still no power than replace the batteries because they are dead. The batteries in the scooter need to be kept charged. If the scooter has not been charge in two weeks to a month and over. They are probably dead and need replacing. Find replacements at razor.com
If it is a fuse problem then try looking for a fuse box in the controller or charger. If not then take it back, unless stated in the manual that you need to enter a fuse before it will charge, the scooter should charge right out the box.
Another thing you might want to try is to turn the scooter off before charging.
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
