Question about Maytag Dishwashers
Our dishwasher is not dispensing the soap. I have tried using the cubes (stays in wells), tried powder (it turns to a cake of soap) and I have tried liquid but you could see it ran down the door. Some dishes appeared clean, others had a film or soap on it. Mind you, the door to the dispenser is open when you open the dishwasher but the soap doesn't dispense. I have ran cleaner through the dishwasher but doesn't help. The machine is approximately 3 yrs old. We purchased it from Best Buys and discovered it is now out of warranty and Best Buys does not offer warranty renewal. I will not buy from them again. Please advise.
  • 1 more comment
  • Arleen Davis Jan 18, 2011
    My husband wants to know what setting does the heating coil need to be at (110 or 120) for the soap dispenser? Thank you.
    Okay, my husband is going to take the door cover off today. You said it has to be 120 volts for the soap dispenser to work. Is there a particular setting the dishwasher needs to be at when the dispenser works? Currently, the soap just runs down the door. Is there any suggestions you can give my husband what to look at and do when he takes the door cover off to correct this problem?
  • Arleen Davis Jan 19, 2011
    Our Maytag dishwasher's model #MDC5100AWW and the serial #29345825EN. Another expert told us to check the metal strip and there is no metal strip. There is a plunger that operates the soap door and then there is one that lets the heat out when drying. Would you look up our model and serial number. The book for the dishwasher we have doesn't offer any help. Thank you.
  • Maytag Master
  • 43,501 Answers
From what you are saying the problem is NOT with the soap dispenser....it is doing it's job and is opening....
The problem is that either your heating element is not keeping the water hot enough to disolve the soap or the water is insufficient to disolve the soap...
I think it is probably the heating element...
To check it for sure you would need to OHM out the lement or get an amp metter on the wire to it when it should be heating...this can be done from the front by taking off the kick plate and then running a cycle and checking for amp draw on the element when it should be heating...
here is the elment for your dishwasher
http://www.partselect.com/PartDetail.aspx?Inventory=2099740&SourceCode=1
I would also buy parts number 1,2,3,31,32,33,34 from this page also...
http://www.partselect.com/ModelFrames.aspx?ModelID=147371&ModelNum=mdc5100aww&mfgModelNum=&ManufactureID=1&Selected=53409&Position=7&mfg=Maytag&Type=&Mark=4
The spray arms get worn and then they do not spray as they should even if they are clean....
Dishwasher Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jan 19, 2011
  • 4,323 Answers
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Dishes are not clean if water is hard or when more detergent is used than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine. Hope this helps...
Please post back if more information is required.
Daniel
Posted on Jan 10, 2011
  • Daniel Scott
    Daniel Scott Jan 18, 2011
    120
  • Daniel Scott
    Thanks for your reply...no additional suggestions though the unit can be run on any cycle.
SOURCE:
I turn the dishwasher on it runs the cycle but doesnt clean and the dish washing powder stays like that and doesnt get used
Your soap dispenser is not opening, This can be due to a broken solder joint in the electronics or a faulty soap dispenser.
Mar 06, 2012 | Dishwashers
Powdered soap residue (cascade) sticks in the dispenser after dishwasher has completed wash cycle. I have tried the new gel pacs and they also seem to stick to the dispenser even after the the dispenser...
The best solution is to use the compressed powder cubes, the will fall to the bottom of the dishwasher as soon as the soap cup opens. New dishwashers use so little water that they dont do a good job of getting all the phosphate free detergent out of the cup. The cubes work fine and you will have no more residue
Jan 25, 2011 | GE Dishwashers
Powdered dishwasher detergent stays stuck in dispenser after wash
There is a rather delicate mechanism which controls that soap door. Often this is the first part of a dishwasher to cause trouble. Instead of using the powdered detergent in the soap holder just pour the measured amount into the floor of the machine.
Once you have used up the powder, you might wish to consider a tablet which also just gets tossed.
Sep 18, 2009 | Dishwashers
Powdered Soap Dispenser
The soap door doesn't open fully on that model, and usually flips fully open as you open the dishwasher door.
It relies on the top spray arm turning to 'wash' the soap out of the drawer - and that will be the problem.The spray arm isn't turning.
Check the spray arm for blocked jets at the very end - use a pin to clear them out, or replace them - check both spray arms. Make sure the spray arm rotates freely also.
Remember the dishwasher isn't a garbage disposal unit - remove food deposits from plates etc before loading the machine. Run a dishwasher cleaner through the machine now and then. Food like pasta, or fruit pips often get carried to the end of spray arms and block them.
If using a 30 min rapid wash program ONLY and dishwasher tablets, put the tab in the cutlery basket as it wont have time to dissolve fully if you put it in the dispenser.
Feb 02, 2018 | General Electric Profile PDW7980NSS...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Bosch #SHU9955 Integra dishwasher for the last three uses, the soap dispenser door was open with the powder soap caked in the lowest one half of the pocket dispenser. The dispenser door locked and unlocked...
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Oct 09, 2008 | Bosch Dishwashers
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Soap cake not dispensing
it is highly recomended that you use powder detergent only absolutley no blocks or tabs or gels
Oct 17, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
285 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
