SOURCE: I cannot pair my Nokia N95 with HBH-608 Akono headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
SOURCE: How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing that...it workss....
SOURCE: how do i connect my HBH-600 bluetooth headset to
hi thanks for using fixya!
Connecting a Bluetooth headset or hands-free speaker unit to your phone involves setting the headset to “discoverable” mode; check the headset manual for how this is done, as it varies by type and model. You’ll also need to find the headset PIN code in its manual – this is usually 0000 or 1234, but again it varies.
Go to Bluetooth menu – from the main menu highlight Settings (Figure 1), click Select, and scroll right to highlight the Connectivity tab. Highlight Bluetooth (Figure 2), click Select and then highlight Handsfree (Figure 3) and click Select.
When prompted to ‘Add a handsfree device’, choose Yes (Figure 4), and your phone will look for all discoverable hands-free units (Figire 5). Select the one that you want from the list that appears and enter the hands-free unit’s PIN code when prompted. The pairing will now be complete.
Once paired, you’ll find the headset listed under the My devices menu in the Bluetooth settings area, from where you can connect and disconnect it.
Hope it will help you. If you need further assistance, let me know!
Regards!
SOURCE: Master reset HBH-PV702
How to restart my hendsfree? pls answer me, i can connect it with no one
