Question about Yahoo Mail
On iPad, yahoo mail has an outbox and there are messages stuck. Cannot delete or send due to error. Yahoo mail on mac or pc shows no outbox so cannot access. How do I delete messages from iPad Yahoo mail outbox? Thank you, Adrian
  • Anonymous Mar 21, 2014
    Photo stuck in outbox
    New Friend:
Tap on e-mail and drag to the left, the "Resend" button cahnges into "Delete" and then just press that. I could not find this anywhere else and just accidentally figured it out.
Posted on Feb 27, 2013
  • Stephen Farrar May 12, 2013
    Thanks for that tip. On the IPad each of the unsent messages piling up in my Outbox is listed in a vertical stack down the left side of the page. By pressing and holding and sliding my finger to the right on each email listed a delete button showed up. I was then able to delete the message from the outbox. Would like to understand why the messages didn't send as they are random in size but at least I was able to clear my Outbox. I tried everything else on numerous threads such as putting IPad into airplane mode, turning off WiFi and trying to send with 4g, etc and nothing worked.
  • Circleforever Jun 13, 2013
    Thanks, thanks, numerous thanks,.... After searching for so many hours and had tried all the mentioned suggestions, too, this is the only solution worked.
    New Friend:
Having same problem....did you resolve? If so, how?
Posted on Oct 07, 2011
SOURCE:
How do I delete a blocking sent email on my ipad?
This is one way I've found to delete an email stuck in the outbox (which is what it "sounds like" you are asking...)
1. change ya smtp settings so the message defo wont send!
2. send a test email to anyone
3. it will attempt to send but oversiously fail...
4. hopefully the outbox should be listed with 1 message waiting to go out...
5. if not, try going into the Activity Window and canceling the send command, that should show it up...
6. click the Outbox and the will be one message listed...
7. goto View -> then Show Favourites Bar
8. you should see a favourites bar appear...
9. simply drop and drag the Outbox into your favourites bar...
10. if you restart ur laptop or close mail and then the Outbox has disappeard, simply click the Outbox in you favourites tab and woop woop it should appear in the Side Bar
Oct 31, 2014 | Apple iPad 2 Wifi 16GB
What will happen if i delete my email account
If someone sends a email to your "deleted account" it will bounce back to the sender with some kind of a undeliverable message, such as "account does not exist" or may be just "undeliverable!". The error message the sender will see depends on wich mail server or service they use.
Jul 11, 2014 | Yahoo Mail
Please help i trying to send an email to my brother in the usa who has a aol.com email account. evertytime i try to send it i get an error message as follows cannot send mail the server rejected one of...
Open your 'outbox' folder -- there might be one message "stuck" there, due to having an invalid ID.
So, every time that you open your E-mail program, it tries again to send that same message, and, of course, fails to send it. So, just DELETE that E-mail, since it repeatedly cannnot be delivered.
Nov 30, 2010 | Computers & Internet
Hi guys, am unable to send mails in outlook 2003 if i send it sits in outbox without any error message.I tried all the possibilities of changing outgoing port 25 to 587,text format html to rich text and...
try to delete all Send messaged in your Sent folder in your Outlook. Because there is limitation of 2GB per folder, and if you reached it then all messages in Outbox can not be sent because they can't be copied to Sent folder.
Apr 19, 2010 | Microsoft Windows XP Professional With...
Can received & read but cannot send yahoo mail from iphone
First step is try reseting the network settings. You can do this by going to settings/general/reset and reset network settings.
This will drop you off the network and reset your phone. Bringing your phone back up with current network settings.
Try sending mail. If this doesn't work, try changing your outgoing mail server.
Go into settings/mail, contacts, and calendars/(your yahoo account)/Outgoing mail server.
This will bring you to a list of mail servers, your primary server being the yahoo server with the AT&T smtp server under other.
Click on your primary yahoo server and switch this server to off. click the blue smtp arrow on the very top left. This will bring you back to the server list. go to the AT&T smtp server and turn this server on.
Go ahead and exit out either by the arrow or the home button.
Access your yahoo account see if you can send mail.
Sep 30, 2009 | Apple iPhone Smartphone
I cannot send email to using yahoo account
You must allow your router access to send out mail. other wise it will keep the messages you send in the outbox. go to your router setup or type your router ip address in the internet browser and manually enable the port 465 you may have to goto applications and games tab if you have a linksys router. Also enable ports 80 for internet,25 for simplemail transport protocol (SMTP),110(e-mail),443secure (bank account information) this will allow the router the proper ablity to send and recieve e-mails.
Sep 26, 2009 | Computers & Internet
Outlook 2007 - Emails sticking in outbox.
Be sure that only one instance of Outlook is running.
You can verify this by openning the tasks manager and ordering process alphabetically.
Kill all redondant Outlook processes.
Feb 17, 2009 | Microsoft Office Outlook 2003 for PC
Yahoo mail /Plus log on, send
if you were in New Zealand,
www.yahoo.co.nz
elsewhere in the world,
www.yahoo.com
or
www.yahoo.com.au
www.xtra.co.nz yahoo affilitates in New Zeaand
You should contact your ISP and they can reset any issues you are experiencing,this may be a simple set correction,
Jul 13, 2008 | Computers & Internet
Windows Mail
Thank you for your offer of further assistance - the problem had been ongoing for upwards of 2 weeks - it is now solved having discovered that the Windows talktalk format had been changed.
Could you please advise me of how to claim a refund and once again apologizing for the inconvenience caused.
Ramona
Jun 30, 2008 | Dell XPS 200 PC Desktop
Yahoo Mail Logo
2,420 people viewed this question
Top Yahoo Computers & Internet Experts
Mike
Steve Allison
Steve Allison
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
