LG LMV1680ST Microwave Oven Logo
Posted on Jan 10, 2011
Hi, I am having a LG MC-7148MS Microwave. I am trying to use the utility corner 5 option i.e. dehumidification. But once selected, I am getting LOCKED sign in the display and START button is not getting pressed. Please suggest how this would work. Thanks, Arpana
5 Related Answers
Anonymous
  • 242 Answers
  • Posted on Apr 10, 2009
SOURCE: 14 month old LG Microwave. The control panel is
Very common , You need to replace the switch membrain , this is the entire touch pad , they are not to much $ , and you should find it easy online.
Phil
Anonymous
  • 52 Answers
  • Posted on Apr 23, 2009
SOURCE: microwave stopped working when i pushed the start button
Yes. The white inside the glass that you are describing is a blown fuse. To find out what size fuse it is look around the base or top of the fuse. You will see engraved something like "125V 5A. You can pick these up at Home Depot or Lowes in the electrical isle. You can also type www.google.com and enter the word "fuse" and then the size it is. (125V 5A) If you have found this information at all helpfull, please rate my solution. Thanks D. Lange
Anonymous
  • Posted on May 22, 2009
SOURCE: Microwave has stopped working and now I receive a flashing No10 in a square and a flashing No 1 in a square.The rest of the oven works, the convection side, What now....help!?
My wife cannot wait forever for me to solve the problem with our Microwave....so I nhad to bite the bullet and take it in to LG for repairs.
Thanks for the good site
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 07, 2009
SOURCE: LG LMVM2075 Microwave Control panel does not work
The keypad has failed and it is available as a part of a new outer door panel, whose part number is 383EW1A130E for $103.19 plus shipping.
You can get it from Encompass here or you can call them toll-free at 866-779-5835.
For disassembly info, you can see the service manual at our site:
http://www.microwavedisplay.com/lmvm2075sb_sw_sm.pdf
It does not contain part numbers, so you will need to contact Encompass.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Anonymous
  • 161 Answers
  • Posted on Jan 25, 2010
SOURCE: Microwave Buttons Stuck
You have a bad control panel contact LG for a new panel.
MICROWAVE MODEL 8083D MODEL MC8083D PLEASE SHOW THE INSTRUCTION MANUAL
Hi Denise, I send you the link to download the user manual of the Microwave LG
Regards Franco Dosil
Hola Denise, te env?o el link para que descargues el manual de usuario del Microondas LG
Saludos Franco Dosil
https://www.lg.com/za/support/support-product/lg-MC-8083D
NOT AUDIO PLAYERS - ITS A MICROWAVE/CONVECTION OVEN
x
I WANT THE MANUAL FOR MODEL MC 8083D
xx
Hi, I have mc-7148ms microwave it is not working when power is turned on.Though I have noticed that one red light is flashed for a sec as soon as power is switch-ed on.
Bummer - sounds like you might need a processor board. The red light exonerates the fuse and power coming to the unit, and I have a feeling that it's something expensive - sorry!
My LG MC 7148MS is not working. Light is on and inside tray is taking round properly but it is giving heat
If everything works, but the microwave oven does not heat, this is commonly caused by a failed magnetron. The magnetron is the heart of the microwave oven and produces the RF energy that is required to heat your food. In order to replace a defective magnetron, you will need to consider the following:
1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven).
2. Ensure the oven is UNPLUGGED before servicing anything inside the cabinet and remove the exterior case in order to access the magnetron. The High Voltage circuit in these ovens produces between 3,000 and 4,000 VAC and should not be worked on unless you electronics saavy. In addition, these ovens should NEVER be turned on, or serviced with the exterior cabinet removed, or high voltage network protective cover removed.
Here are several websites that you can use that illustrate how the oven is assembled:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
Repairclinic.com is another great website for parts, and has part illustrations/photographs, but does not have the exploded view to show how the appliance is assembled.
NOTE: If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart.
3. The magnetron replacement cost will depend upon the MODEL NUMBER and generally costs between $100 and $200.
Use your appliance model number and review the parts illustrations at the recommended websites to identify and locate parts, and to see if this is something that you may be able easily take apart and reassemble.
If you have any questions, please post back and let me know. I hope you find this information helpful.
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
21helpful
5answers
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Lost instruction manual
Hi - You can download the manual from the link below:
MC-924JLR
Please update the question & let us know if the information given was useful to you - Good Luck!
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
