Question about JVC Everio GZ-MG130 Camcorder
HDD ERROR - JVC Everio GZ-MG130 Camcorder
  • 2,517 Answers
Hi there clean the camcorder head and the reset the camera. After that try.& let me know.
Posted on Jan 10, 2011
6ya staff
SOURCE:
Why does error code 8001002f appear when formatting disk ?
Remove and reinstall it, if it still gives the error code it means the hard drive is bad or going bad. That error code means the Ps3 can't read the hdd or certain sectors of the hdd. Best to always use a new hdd when replacing the hdd in your Ps3 anyways. I'd a hdd dies andyou haven't backed it up you lose aall your game saves and anything that is not tired to a psn account.
Jun 27, 2014 | Sony Playstation 3 (PS3) Console
System error hpdesignjet 1050c error 09B300 007A0EED
09Bxx0 errors relate to hdd read fail,#
there are two causes for this -1) the Hdd has indeed failed
2) the power supply in particular the hdd power supply(part of the main PSU) has failed- easiest way to see is connect a diferent hdd to the machine and see if it spins up if it does replace the hdd if it does not then replace the psu
Oct 11, 2013 | HP DesignJet 1050c InkJet Printer
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
I AM GETTING HDD FORMAT ERROR E:31.00 SONY DCR-SR68
I AM GETTING HDD FORMAT ERROR E:31.00 SONY DCR-SR6E. PL.SOLVE THE PROBLEM
Sep 11, 2011 | Sony Handycam DCR-SR85E HDD Camcorder
Canon Image Runner 2200, receiving error message 602-0003
It's related to copier HDD try with some technician to replace HDD or reinstall HDD software.
A data read fault of the HDD is detected when the HDD is started up. or
The wiring is faulty (short circuit, open circuit). The HDD is faulty.
also check -
Are the connection and the cable between connector J1025 of the main controller PCB and the connector J2005 of the HDD normal?
Jun 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
In Ricoh aficio 401
The SC360 is Hard disk drive error 1. This means that the machine does not detect the connection signal from the HDD.
CHECK THESE; poor connection between the HDD and the HDD controller,
the AC power connector to the HDD is disconnected,
HDD defective,
HDD controller board defective,
BICU defective.
Make sure all connections are tight and secure, make sure power is connected securely, make sure HDD ( hard drive) is not bad if so replace. If the above are fine, replace the controller board and if the problem is still there, replace the BICU board.
Nov 15, 2008 | Ricoh 6513 Copier
JVC Everio GZ-MG130 Camcorder Logo
74 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
