Either the tub gasket needs replacement (item 3) in this diagram. or the door base gasket needs replacement. Alternatively, the door vent seal could be leaking. Item 4 in this diagram.
Hope this helps.
Thanks. I will look into those and probably replace them this weekend.
Clean the vent at the top left corner of the door. Your water is probably not returning to the main part of you dishwasher due to a vent filled with mold and crud. Easy fix. This will cause the water to leak from the lower left corner of the door.
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Leaking Dishwasher
heatman101
