HP DeskJet F380 All-In-One Printer Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer status always indicates offline unless I reboot. Only lets me print once then goes offline again. I have a Lenovo ThinkPad. Thakns
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on Jan 10, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
Helped
29547
Points
299
Delete the ICON of the printer
Restart the computer while the printer is ON
It should reinstall the drivers and then you printer will work fine
3answers
My printer keeps going offline. What can I do to get it back online?
As you get the HP printer offline issues or offline error messages on our device display screen, it's time to troubleshoot it. Go for a quick scan of your device and check if the offline errors still remain. Among the available scan tools, we have the HP print and scan doctor tool. Cross check if the software version that you use is the latest one. You will get more help and guidance to get rid of the error if you ring the contact number +1-844-510-3770
2answers
Ricoh Aficio MP C6000 Printer Offline
check weather u have connected all cables properly
then check for your printer driver
after checking if everything is proper then right click on mycomputer select manage then serch for the installed driver then right click on pirticular driver go to properties then select driver tab then select rollback option if this dosent works then go to control pannel then go to printer n scanner option delet the installed printer and add it again
11helpful
6answers
Epson printer offline
In this section, we provide some practical ways to resolve the Epson Printer Offline Issue. Simply follow the mentioned teachings carefully and fix this error on your own.
If your Epson printer is displaying an offline message, it means that there is some connectivity problem between the Epson printer and PC. ... Incorrect printer settings where your printer is not set as "Default Printer" may make your printer go offline. An outdated printer driver may stop your printer from functioning.
In the same way, How do I put my Epson printer back online?
Verify The Printer Connection
Update Epson Printer Driver
Check Printing Status
Restart The Print Spooler Service
Add A Second Printer
Hopefully, now you can surely Resolve this issue. I Hope, this content is valuable for you to solve the Epson printer says offline windows 10.
Epson Printer Not Connecting to WiFi
Epson Printer is Not Responding
2helpful
I have and Canon iR3570 and when SNMP is disabled the printer goes offline and network printing ends. Enable SNMP and change the default community to something more secure and printer goes offline and...
It's possible that the SNMP Status Enabled box is checked on the print server (Printer/Properties/Ports/Port Settings). When you disabled SNMP or changed the community name on the printer, the server was no longer getting status updates and so flagged it as offline. Make sure the community names match.
13helpful
It suddenly went offline after printing a document. When I turn it off & on again, it manages to print the current job but then goes offline.
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
This fix was given to me from Xerox Tech support.
SHARP AL-2040CS offline after reboot
Official Sharp driver had set "use printer offline" setting in the printer properties context menu. After unselecting the "use printer offline", printer is printing again, even after reboot...
Epson CX5800F printer Netgear PS121 Print Server difficulties
Here is a workaround:
http://newsgroups.derkeiler.com/Archive/Comp/comp.periphs.printers/2007-08/msg00456.html
Another thing to try if it STILL doesn't work is
Printer&Faxes>>Properties>>Advanced>>"Print Directly to Printer"
Just remember to restart after you try both of these. The Status Monitor in it's current for (at least for me) simply sucks.
k24674
Grand Canyon Tech
Grand Canyon Tech
