Hi
This issue appears due to stuck keys on control keypad or due to moisture/shorted connections on the keypad. Sometimes this appears when the door is not closed or door lock switch is failing. Turn off the power to dishwasher, unplug the power cable from outlet or shut off the breaker. Use a multimeter and make sure that the connection to door switch assembly are fine, also check the continuity of the door swiches (when closed). If continuity is present you would need to check the connections to the keypad. Try disconnecting the P1 connector(connects keypad to control board) and then reconnecting it, check if the problem is still present. Replace the keypad if the problem still appears. Please check the below pictures, they might help you--
Link 1 (Door Switch)
Link 2 (Keypad)
Hope this helps... Please post back if you need more information.
Daniel
The door switch worked fine. Disconnecting the P1 connector and then reconnecting it fixed the problem. Thanks.
