Open the Program Compatibility troubleshooter by clicking the Start button , and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
Follow the instructions in the troubleshooter. If you cannot install a program, insert the
installation disc for the program and, using the troubleshooter, browse
to the program's setup file, usually called Setup.exe, Install.exe, or
something similar. The troubleshooter is not designed to work on
programs that have an .msi file name extension.
Install it and then run it in compatibility mode, to do this, right click on the programme and select properties, go to the compatibility tab and select the mode in which it last worked for you. Click apply then ok and run the programme.
