My whirlpool LHW0050PQ4 worked fine last week, but today after I powered on , choosed type of washing and water level then pressed start, but nothing happened, no water in and no spin. I tried several times, and the same, I can see the wash light was on and after a while, the done light was flashed, can you please let me know what should I chek and what to do? Thanks in advance.
You could have a bad level sensor or a pinched/severed/unattached vacuum hose which goes to the sensor device. The washer cannot determine how much water the tub is filling so the water keeps going in. I would check that the vacuum hose is simply not connected and that would be the easiest fix. The sensor device is usually located inside the control panel area and you can start there.
I also face the water reuse error problem on the top loading Whirlpool washing machine. Powering on is OK. selecting the program also goes fine. The moment start/pause button is pressed, little water flows to draw detergent and immediately the "water reuse" LED lights on. Further to that nothing happens. Any solution?
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock. 2) if do not obey press and hold END OF CYCLE, wait about 10seconds 3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
