Computers & Internet Logo
Posted on Jan 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello My name is Mario . I have an Advent Verona and a white strike appear on my laptop screen every time I turn on the laptop. It s a new one i have it for 1 month. And the keyboard is very very anoing. I really regret the choice I made with this laptop. Can u please help me? Thank you
alivia cora
Level 1:
Habit-Forming:
New Friend:
  • Contributor 11 Answers
  • Posted on Sep 05, 2018
alivia cora
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
11
Questions
0
Helped
1845
Points
79
I suggest you that when you go for buying something please make note of some points of your budget and your need and your experience of that type of things. and if you are not satisfied with your current laptop you should change it as soon as possible
I can suggest you review this type of article it will help you to find the perfect laptop for you. read this: https://fixingblog.com/5-reasons-gaming-standard-laptops
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Jan 09, 2011
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689282
Points
8444
If you have only had it a month then it shoud still be under warranty. Best to return for repair or replacement rather than trying yourself and perhaps voiding your warranty.
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Black screen on advent verona netbook
A black screen on startup can be so many things! I have learned this lesson the hard way. Never turn off the computer when it is half way through the boot procedure. Even when it is taking forever, or having a major problem you must let it run through if possible. Interrupting it once may be ok, but twice or three times is a no no. After you have carelessly restarted and shutdown a few times the black screen may appear. But this time it may be beyond repair for the average computer user.
Check Below Link for Instructions:
http://tips4pc.com/articles/computer%20troubleshooting/how_to_repair_a_damaged_boot_sec.htm
Good Luck!!!
White line down centre of screen advent verona
Those are called "stuck pixels" .
Try this:
1.Turn off your laptop.
2.Get yourself a damp cloth, so that you won't scratch the screen.
3.Apply pressure to the area where the stuck pixel is. Try not to put pressure anywhere else, as this may trigger the creation of more stuck pixels.
4.While applying pressure, turn on your Laptop.
5.Remove pressure and the stuck pixel should be gone.
If the computer is still under warranty, return it for repair. If the warranty is dead, you may wish to try some of the home remedies listed in this article:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
White line running through cente of screen
Hi there, If the line appears already from when you switch on your Laptop then it means your LCD/Screen is busy breaking. The white line is normally caused due to loose contacts inside screen and cannot really be repaired.
regards
2answers
1helpful
Received gift of Advent Verona laptop BUT no manual with it ie user manual. We need user manual to set it up - its' O/S Windows 7 Home premium can you help? product code 450415
The Advent Verona manual can be downloaded from http://support.thetechguys.com/Uploads/%7B7bf65b24-9f32-44ce-88e4-b1bc102205b0%7D/Advent%20Verona%20User%20Manual.pdf
Grand Canyon Tech
Grand Canyon Tech
