Make sure ur batteries are fully charged and ur using the right ones for ur model reset ur transmitter to factory default, it sounds like the esc is detecting something wrong when u go to use it bad battery if its a lipo may have ran it to long which can mess them up, I would clean the button on the esc really good, if the truck is making that noise the esc will try to shut down the system if all else fails send in ur esc to traxxas and they will send u a new one for like $50 buck let me know if u get it going
SOURCE: traxxas stampede the green light comes on for a second then off
All it was that the brushes were dirty, and they were stuck to the motor. The dealer gently used a screwdriver to move the bushes away from the motor a bit and let them snap back in place. Then it worked. I,m such a new R C guy.
SOURCE: My RC Traxxas Stampede stop working. The steering
Spin the rear wheels and make sure nothing such as a small stone is binding something up in the driveline. Check to make sure the motor has not gotten disconnected from the ESC. If you still have problems with it post again and I will try to look further into it.
SOURCE: My brand new traxxas stampede broke
If the pinion and spur gears are not touching, the motor can be loosened and adjusted so that the gears mesh. They need to have just a little bit of play between them. If they are to loose the spur gear will get stripped. If they are too tight it puts extra load on the motor and can damage it.
SOURCE: electric rc truck turns on but dont move
The electronic speed control or motor may have been damaged. These trucks are not waterproof, I would avoid water as best as possible.
SOURCE: traxxas stampede eletric r/c
If u are running a lipo in the xl5 you have probley burnt the brushes it has happened to me with three titan12t`s. Do not run lipo with the xl5 the titan 12t brushes cant handle the heat the brushes get so hot they just fall out of the brush holder. I have gone threw three titans 12t @ 25$ each save you money and get the brushless upgrade u will love it. Then u can run ur lipo with no worries. Hope this helps.
