Hi!
This is almost ALWAYS caused by a problem (a short OR an open) in the coax cable from the VHF radio to the antenna. An easy way to check is to JUST insert the PL-259 connector into the socket of the radio, making sure that ONLY the center pin is making contact with the socket. If the weather channels come in clearly, then it's usually an easy fix. Simply check the connections at each end of the coax, looking for a poor center pin solder connection or perhaps a bit of the ground braid is shorting out the center lead. A magnifying glass is a great tool to spot problems.
If the coax proves NOT to be the problem, then the fault is likely to be in the radio itself and is probably a bad solder connection where the antenna chassis mount attaches to the PC board.
Hope this is helpful.
Good Luck!
