SOURCE: Magnavox 50ML8105D/17
On e-bay there is one. just type in the m# of the tv and you will find one for about $50.00 (magnavox ballast) in the search window will work also. I need the power supply for this set, so if you happen to find one can you email me at [email protected] thank you and hope I could help.
SOURCE: where do i find the
Take off the speaker screen on the bottom of the set, next to the left speaker (if facing the front of the tv ) there is a plate with two screws, remove this plate and the lamp module is behind it, remove it and replace with a new one
SOURCE: TV Magnavox 50ML8105D/17 Problem
Try cleaning the filter........sometimes it gets clogged and then the set overheats.
SOURCE: i have a Magnavox 50ML8105D/17 the picture is getting darker
If the picture has gone darker and kind of "foggy" the likely cause is that the cooling fluid in one or more of the picture tubes has become discolored. The only way to check for sure is by looking directly at the face of the CRTs (front or back cover/screen removal). Have a service call done and ask how much they charge to check this. The fluid can be changed but it's abig job (usually $300-400)
Testimonial: "great help!!!"
