Leviton R01-PR180-1LI Decora 180 Degree PIR Motion Switch Ivory Logo
Posted on Jan 09, 2011
Where can a get information how to install a automatically turn light swicht leviton model occupancy sensor m,odel
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 09, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2972
Points
5
What's the problem? You can get instructions at leviton website but also suggest you read competing products manuals to build perspective. These are difficult to install in 3 way wiring situations. In 3-way they only seem to work well when wired to load not line side. In 3 way I suggest you wire in 2. There is a certain way of doing this. I just looked at instructions for Leviton's competition.
1helpful
Wire occupancy sensor to control receptacle
Your description doesn't explain the circuit, the function of the wires or how the switch controls the outlet and whether the switch is a single pole or two-pole switch. Without such details it is difficult to visualise the circuit.
I advise before you go further to test the sensor in a known good and correctly wired outlet using a length of cable and a suitable plug for the outlet. It is possible the unit is faulty. If it functions correctly on test you will need to understand the circuit and the function of the wires before you rewire it to assure success.
Light turns on by itself
Sometimes they just need to be reset
1 turn off power to switch (Circuit Breaker off)
2 wait 30 seconds
3 re - turn on power to switch again (Circuit Breaker on)
4 wait for lights to turn on by themselves ( about 15 seconds after power is turned back on)
should be OK after this remember to not enter the beam after power is turned on ...... (see #4 above) as this would make switch beam super sensitive. Hope this helps
Trying to set switch for 5 minutes , and i only get 30 seconds or 15 minutes
Which brand and model number specifically?
Leviton: 1-800-824-3005
Leviton Decora manual says:
"PR180 operates by detecting motion (such as body heat) within its field-of-view (area of coverage) and automatically switches lights ON. When motion is no longer detected, lights remain ON for a selected time and automatically switch OFF.
Adjustable light and time-delay controls are located on the front of the device."
The manual is not specific about set times.
In any case, the device has off-delay timing circuit, so once infrared heat is no longer sensed, the delay period begins, and once the delay period expires, the device is switched off.
Delay timing circuits are common for many home and industrial applications.
As a general rule, delay timers can be set for different time durations, however the Amazon page that sells PR180 product does not specify available time settings either.
Legrand RW3U occupancy sensor spec sheet says adjustable time delay 15 seconds 5 minutes, 15 minutes and 30 minutes
http://www.amazon.com/Legrand-RW3U603I-Occupancy-Vacancy-Decorator/dp/B005FMLL5G
Delay switches
Here is manual delay-time switch Tork SS20 SS13 where you can 'fine-tune' the delay circuit, but my experience is that exact 5 minutes is not easily set:
http://waterheatertimer.org/images/Paragon-ET-series-243.jpg
GE 15318 switch offers 5 minute, but there is no guarantee that you can get 5 minutes exactly:
http://waterheatertimer.org/images/GE-15318-countdown-timer.jpg
My conclusion is that there are very limited delay-time choices with this model number, or device is defective and suggest to call Leviton.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I installed the PR180 switch in my garage with a 4ft dual t-8 flourescents bulbs. When the motion sensor timer turns the light off the flourescent bulbs stay slightly lit, as if it were on a dimmer...
There is nothing wrong with the switch or your wiring. The Leviton R01-PR180-1LI is not designed to work with flourescent lights. A lot of electronic controls will bleed through a small voltage when in the "OFF" state. It's just enough voltage to make the ballast in the flourescent light try to fire but not enough to let it fire the way it is supposed too.
What you need is a motion switch that is rated for flourescent lights, such as this :-( :
http://www.smarthome.com/2520W/Leviton-ODS10-IDW-Commercial-Grade-Wall-Mounted-Occupancy-Sensor-White/p.aspx
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
I have installed (or tried to) three different Leviton PR 180s in my front hall. All operated the 23 watt fluorescent bulb in the fixture satisfactorily, but were not affected by the ambient light; that...
The Leviton PR180 is a motion detector, or occupancy detector.
It senses infrared heat from a person's body.
I am looking at the manual from Leviton.
Maybe this will help:
There is a small adjustment screw under the wallplate where you can adjust light sensitivity.
Use fingernail or small screwdriver.
Turn control towards the "-" sign and lights will turn on in 'less lighting conditions'
I will be here for a few more hours.
Add a comment and I will help further is needed
LEVITON IPPP10 WIRING QUESTIONS
White can never be connected to power. Look at the paper provided with device. It will tell you the incoming power wire and the load wire. These must be correct.
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
