I can't configure my VN-2100PC on my Win XP System Digital Wave Player can't "see" my audio recorder. And I can't find the Win XP drivers. Any help? Thanks!
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
Yes you got a new computer but unfortunately the vn-2100PC is not compatible with 64 bit OS's neither XP 64bit or Vista 64 bit...therefore it will also not work with 7 64bit.
Feel free to verify by checking at www.olympusamerica.com
I called Olympus and found out that the software needed is the same as is used for Windows XP. So download/install that from their site + the drivers/update for windows Vista (works with 7 as well).
on xp, you will need to convert the recordings into 16 bit wave file through the sound recorder on your computer... you may need to call olympus for more details
Here is the download instructions for the VN recorder software it work with the VN 240Pc up to the VN 4100PC and Widows 2000 - VISTA.
Digital Wave Player (2.1): is available via download as a courtesy, please follow the instructions below:
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
