You need to check if it is charging the battery. Insert another battery into the phone and power it on to see if it will turn on, if it turns on, then you know that the problem is from the battery. Then you replace the battery. If you insert a battery into it and it still does not power on, then you know that the problem is from the power ic. It is bad and need to be replaced.
Hope this solved the problem.
