Occasionally when i wash i find my washer stopped with the code lr on the display. This doesn't happen all the time but it sounds like if I don't get it fixed it will. Any ideas? Occasionally when i wash i find my washer stopped with the code lr on the display. This doesn't happen all the time but it sounds like if I don't get it fixed it will. Any ideas?
Washer filled up with water. Then would not spin. Clothes locked in washer filled with water.Washer filled up with water. Then would not spin. Clothes locked in washer filled with water.
Washer is full of water and clothes are sopping wet. Will not spin.Washer is full of water and clothes are sopping wet. Will not spin.
AnonymousMar 16, 2014
getting constant error, can clear with spinning only and half or less a loadgetting constant error, can clear with spinning only and half or less a load
You can't post conmments that contain an email address.
Take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
I would check the balance of machine by using a leveler and checking the bottom leg adjustment on all 4 legs then check the
suspension springs, counter weights, dampning straps etc.
Looks like another motor/motor control panel replacement. This machine has a faulty motor/motor control board, it has been re-engineered with a replacement. Has yours been replaced?
Have you found the tech sheet behind touch panel and placed machine in service mode to test?
We had the same issue, worked sporadically, didn't drain, got LR code then eventually stopped working.
Check your spin in service mode, if it doesn't spin properly you should find out here. It is a very simple repair in all actuality. Contact Maytag and they will sell you the parts for a discounted price, make sure that you buy directly from Maytag, also check your boot very carefully since that part will also fail and allow water to get into the bottom of the machine where you have electronics.
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
check the drain pump for a foreign object that maybe stopping the impellar wheel from turning.to remove the water use a shop vac attached to the drain hose to get all the water out
same trouble fills with water and just wouldn't wash code lr back panel off belt is fine
