Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Posted on Sep 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My router regularly drops out my wifi signal, sometimes 6-7 times a day depending on usage. The problem is usually resolved by turning power off and on. (Very frustrating as located at top of stairs!) Problem is very random and doesn't seem to have any particular cause. Doesn't seem to matter where my laptop/device is located. Any advice would be appreciated!
Betty Reese
Level 2:
Habit-Forming:
New Friend:
  • Expert 177 Answers
  • Posted on Sep 24, 2017
Betty Reese
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
177
Questions
Helped
44881
Points
381
That's about par for the course. This happens most everywhere and it needs to be reset. Upsetting I know, but most everyone has to deal with the same thing.
5 Related Answers
Anonymous
  • Posted on Jun 08, 2009
SOURCE: Belkin F5D8230-4 Intermittent Signal Problems
When i use Skpe its very interminttent and really annoying ......i think its the router. DOes anyone know how to fix this dam thing????
Anonymous
  • 825 Answers
  • Posted on Mar 29, 2010
SOURCE: N1 Belkin to HP notebook - connection speed drops to 24mbps
It might be because of other electronic devices that works nearby in similar frequency...devices lik microwave oven, inverters, modems provided by the ISP which comes along with a battery backup, especially RCA modem which doesnt allows other wireless devices to work nearby it... try to relocate the router to a well ventilated area, and make sure you have kept the router atleast 5 feet away from other electronic devices...it could help....
Anonymous
  • 98 Answers
  • Posted on Apr 15, 2010
SOURCE: router keeps dropping connection
the problem might be with your dsl line. Check to see if it happens with all phones, sky and non broadband equipment removed from your phone sockets. if it still drops contact your isp.
govinda123
Prashant M
  • 2278 Answers
  • Posted on Apr 22, 2010
SOURCE: My Belkin router data light goes out and drops connection
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
This MAY resolve your issue.
Click Here for more information about router and networking
Testimonial: "Many thanks, will try this. Not very techno savvy tho, so am a bit scared!"
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Jan 06, 2011
SOURCE: Hi. I have Windows 7 laptop
Welcome to Fixya
Sometimes there are pre-installed softwares inside the computer that causing this scenario. Is this a brand new computer? Have you tried reinstalling the driver of the wireless network card? Could you provide me the model/brand of your computer.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
The wifi connects to my hi sense TV however it drops out every couple of days and I have to enter the password again it only last for about 3 days drops out grrrrrrrrrrrrrr
test online speed for wifi..tv needs 40 MB. download speed, also straight line to the tv.check location if it is up or downstairs, in another room. Repositioning tv may help. height of wifi router can affect it. It sounds like you wifi signal is barely in range of the tv, when it drops low and then back, you will have to reenter the security password. can you move the tv closer to the wifi router? If not there are 2 solutions,buy an ac wall plug router which sends your wifi through the whole residence, or a dlink wifi extender to increase your coverage.
What causing that the Wi-Fi connecting at Windows8 faled every few minutes.???
Hi
The normal cause for WiFi failing regularly, dropping out, is due to distance from the WiFi signal source. This distance is not just feet and inches but also dependant upon the nature of objects between the signal source and the receiver. I recently found a case where the signal source had been put behind a large modern TV, and the WiFi signal in the next room was so slow and intermittent that the internet was unusable. Moving the router in front of the TV (in a position where it did not obstruct the picture!!!) cured the problem and they now have fast WiFi internet.
Wifi connection
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel.
2. Analogue video senders used to send audio and video to other TVs in the home.
3. Microwave ovens emit interference in the 2.4GHz band.
4. Wireless speakers and console controllers can cause interference with the wireless router.
5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem.
6. Power cables located near the wireless router can cause dropouts and speed reduction.
7. Fish tanks and mirrors will cause massive Wi-Fi shadow on the other side of the tank from the wireless router.
8. Depending upon the location of large mirrors will reflect wireless signal away your computer.
9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances.
10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
D-Link DIR 685 link drops regularly, I have firmware Ver 1 ,year2009
Try using a different channel. A higher one. Default settings often get interference from cordless land line phones (up to a mile away!!). Channel change usually resolves the issue.
1helpful
My laptop randomly stops picking up my wifi
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Low connectivity for d link 524 airplus g
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Knightpad wont stay connected to my wifi
I have a NetGear WNR834M that keeps dropping the signal. Connecting PC directly to the modem I have no problems maintaining signal.0
I too experience a similar issue with the wireless connection dropping. My wireless devices are within a 20-30 foot distance from the router and all of the devices loose conectivity so I know it's not just a specific device.
My WNR834M is running version 1.4.23NA. The logs file doesn't show anything except for one timestamp the last time it was reinitialized (a forced reboot).
The router's WiFi Channel is set for AUTO and is currectly using Channel 1 (found under Maintenance
I have a HP G70 with an Atheros AR5009 WiFi adapter. I use an Apple Time Machine/Wireless router. My Macs stay connected to the router with no problem. My HP drops multiple times a day. All drivers are...
Hi, did you get this problem resolved? I am having the same issues but cannot seem to find anything to resolve. I have a hp g70 running vista. Sometimes the connection can be stable for hours but then other times it disconnects every few minutes. I know the router is working fine as I have 2 other laptops that never drop the connection and my ps3 and phone always stay connected as well. Thinking now that I have got to take it back
3helpful
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
