Verify the wireless network power switch is on.
The wireless network device in the computer can be turned on and off. The network power switch is located in different places on different computers. See the User Guide for the location on your model. Most models have a blue LED that glows when the wireless network switch is on
Verify the wireless network connection is enabled
The connection to a wired or wireless network can be disabled or enabled. To verify the status:
Post back results so I may assits further if required
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the power lead from the power in put on the computer
remove the side panels on on our computer you will see 4 screws 2 either side unscrew these
then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
i was unable to locate your spicific computer i hope this will guide you
http://www.youtube.com/watch?v=qzFB-URV6EM
Replacing a hard drive in a Compaq Presario SR5010NX PC
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
YouTube video install a second ide hard drive
http://www.fonerbooks.com/laptop_1.htm
laptop hard drive
http://www.ehow.com/how_5451891_remove-hard-drive-ibm-notebook.html
Hope this helps.
utube video install a second ide hard drive
laptop hard drive
hope this helps
