2003 Mitsubishi Galant Logo
A
Anonymous Posted on Jan 09, 2011
Hello. We have an 03 Mitsubishi Galant. We need to identify the fusable link at battery positive cable. Please identify its uses and replacement. Thanks DC
David Belcher
Level 3:
President:
  • Master 1,978 Answers
  • Posted on Jan 09, 2011
David Belcher
Master
Level 3:
President:
Answers
1978
Questions
Helped
1001411
Points
6030
The fuse built into the positive battery cable is the alternator fuse. If it blows your battery will go dead.Your charge light will not come on, your alternator and battery will be operating perfectly but since your battery is not charging your car will go until the battery id dead and just stop. The fuse is the big square part of the clamp and simply unbolts from the actual clamp. It is a dealer only part that runs between $10 and $20 depending on where you buy it. When ever you work under the hood around your alternator always take your negative battery cable off so so do not blow this expensive fuse.
Where to find the location of the camshaft position sensor for a 2003 mitsubishi galant v6 3.0
This video may help ... the sensor is underneath the timing belt cover so it is a bit involved to get to ....
https://www.youtube.com/watch?v=RHMe3S7RQ68
Where is the crankshaft position sensor located on a 2003 Mitsubishi Galant 4 cylinder
Hello, crank position sensor located at the 2 o`clock position hidden behind timing cover and crank shaft pulley. If you look closely in well lit area or use a flashlight you can follow the (CCPS) harness down the right hand side of timing cover to where it goes into lower timing cover on lower right hand side of crank shaft pulley. It can be replaced with out removing timing belt. Please note if the 60,000 miles heavy service interval for timing belt is needed and water pump condition should be observed when repairing the crank position sensor.
2answers
I have a 03 mitsubishi galant need to get it running again. Just had intank fuel pump replaced. Car wants to start but, won't turn over... Help me please!!!
By won't turn over, do you mean it cranks over but won't start, or it won't even crank? If the starter is cranking the engine, check the fuel pressure or verify the pump is working. Just turning the key to on, not start, should turn the pump on for a couple of seconds, to put fuel in the line and up to the engine. If you have fuel pressure, check for spark. If you have spark, check the fuel injector circuit.
If the engine won't crank, you need to check the state of your battery, it should be 12.6 volts to be fully charged. If it is good, check both battery cables for clean, tight connections, check for a good ground connection, and the positive cable that attaches to the starter-make sure that connection is tight. If still no crank, take the starter off to be tested.
Air vent position switch galant 2001 doesn't go to dash board position
I think you should buy repair manual first for your vehicle after that it will be easy for you to solve the problem. Check the link may be you will get something useful here Complete 2001 Mitsubishi Galant Workshop Repair Service Manual
1helpful
2answers
Mitsubishi 2001 Galant battery drain
Do not disconnect the positive Or negative cable while vehicle is running it is no longer an acceptable test and damage to computers could occur as there is no ability to suppress or absorb a voltage spike. If you remove the negative cable to check for an amperage draw that's an other thing. You should use a meter and connect it in series between the neg post and the neg cable once all modules are in sleep mode there should be no more than .3v as a rule of thumb. If more you have a parasitic draw which you could isolate the system/circuit by removing fuses one at a time. When the draw is gone that's the circuit in question.
Removed battery cables to reset check engine light, now cooling fans and ac comp. will not work. it is on a 97 pontiac grand prix 3.8 v6
There are fusable links that are inline to the battery positive cable. Make sure you have good connections or an open connection in the feed wire. It may have been broken upon installation. Question.,.did you install the negative cable first before the positive cable? If so it can short out a fusable link
2007 Mitsubishi Galant battery cables
clean all corrosion off, use baking soda and water and tooth brush, tighten then loosen fasteners slowly to remove use silicone lubricant,
2answers
2002 galant. bad/broken positive battery cable. Can i replace it without the 120 amp fuse or will it fry something
never replace a cable like that without the inline fuse. that will protect the system in case of a short..... BE SAFE.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mitsubishi Expert? Answer questions, earn points and help others
