I am not an expert on PDF's and I also have no experience with Apple OS, but I use a Sony PRS-600 and I thought of something that may possibly help you.
There could be some formatting commands or conditions contained within your PDF file that conflict with the Sony software and prevent portions of the file from being accessed. I suggest you try to reformat the file to see if you can get a "clean" version of the file. To do this you will have open the document and select "Print", however this is done on the MAC. This will send the opened file to a virtual printer and format it into a PDF file, hopefully creating a fresh copy that will be readable on the Sony.
In order for to you to be able to "print" PDF files you will need to install a suitable print driver.. I assume there are print drivers for the MAC, just as there are for the PC. Check the following website for more information on PDF printing on MAC's.
http://en.kioskea.net/faq/454-pdf-for-mac-os
There are numerous other websites dedicate to the download of freeware that can help you set this up.
For example -
http://download.cnet.com/Convert-to-PDF/3000-2084_4-10914935.html?tag=mncol;7
Having enabled your computer to print PDF's, open the PDF file in question on your MAC. Make sure, as mentioned in your message that all pages are accessible, then select the print command and re-print the file to PDF again. Transferring the file to the Sony device will then confirm if this approach is successful. This is not a proven solution but worth trying nonetheless. Good luck.
