I forgot the password to the login of my new laptop. It is an HP Pavilion dv6500, and I got it at Best Buy. Thx
Forgot password to login Windows 8 laptop? You can remove Windows 8 sign in password. For example, when you remember administrator, you can remove Windows 8 login password in Control Panel. If you have forgotten Windows 8 login password, get Windows Password Genius Advanced to remove administrator password and then access Windows 8 without password.
Method 1: Remove Windows 8 password in Control Panel
1. Choose administrator to login into Windows 8 with administrator first.
2. Click Control Panel and see it with Small icon or Large icon mode.
3. Click "Manage another account" to open a new window and choose user account you want to remove its password.
4. Click "Change the password" button and type in no password. Press Enter to go on.
Method 2: Remove Windows 8 laptop forgotten password with tool
It is an effective tool, Windows Password Genius Advanced. Get full version and install it on your another available computer.
1. Run it and insert prepared bootable USB drive into this available computer.
2. Click "Begin burning" to burn password reset disk into USB drive. And don't exit USB from available computer until "Burning Successfully" message pops up.
3. Plug USB reset disk into laptop you have forgotten Windows 8 login password. Start it and set laptop from USB drive.
4. When Windows 8 laptop boots from USB successfully, Windows Password Genius Advanced runs in WinPE environment too.
5. Choose Windows 8 system and select one administrator. Click "Reset Password" button to remove Windows 8 forgot password.
The last but not the least is reboot Windows 8 laptop. But don't forget to eject USB device before laptop restarts completely.
Video tutorial:
https://www.youtube.com/watch?v=-vnCbWlOge0
Have your HP
laptop login password forgotten? Do you have another administrator? Have you created
Windows password reset disk on your HP computer when it is available? Or
whether you have installation CD?
If you have
administrator, just change HP login account to this administrator and access HP
computer with it. At this time, no matter which account, you can easily change
or remove its password on Control Panel.
If you have
password reset disk, on Windows login screen after you type incorrect password,
there will be a message "Reset Password" prompting you to reset forgotten
Windows password with reset disk. Just follow password reset wizard to do.
If you have
installation CD, it will help you to restore HP computer or repair computer.
But it is still dangerous for us to use it because it will delete some
important data on your computer.
In consideration
of data safe on computer, Windows Password
Genius provides a safe Windows password reset environment WinPE. With it
and in such password recovery environment, you will don't need to worry about data
lost or damaged.
This is a video
showing how to use it.
http://www.youtube.com/watch?v=quxuEqpG6f4&feature=youtu.be
If you means you forgot xp password, you can use Windows Password Recovery Tool.It is a good tool for anyone who lost windows password. It can recover windows login password in few steps.
waht to do if forgot HP laptop login password?http://www.youtube.com/watch?v=_7K05cmod...
If you have a bootable CD/USB drive,some password tools can be burn to it and you can boot your computer from USB to run the software,so that you can recover/remove WIndows system password from USB.
Such as Windows Password Rescuer,here I just list the simple steps:
Step 1: Download Windows Password Rescuer
Step 2: Run it to burn to bootable CD/DVD or USB flash drive
Step 3: BIOS setting of your locked computer to boot form CD or USB
Step 4: Reset Windows password on a friendly window after Windows Password Rescuer starts.You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows without login. With this New user account you can logon your locked computer directly.
http://www.daossoft.com/documents/how-to-reset-window-2000-xp-vista-win7-password.html
F you forgot Windows 7 login password
of the admin account, but you have another account with admin rights,
you can use Control Panel to change or remove the password: Choose
'Start' > 'Control Panel' > 'User Accounts and Family Safety' >
'User Accounts'> 'Change your password'.
IF not, you are
locked out of the PC, then, you can use password recovery tools like
Windows Login Recovery, free or commercial, for Windows 7 login password reset soon.
You can download a windows password reset tool on the internet. It can reset Windows login Passwords. You could get back into Windows just within few minutes. I recommend this site http://www.reset-windows-password.com
You could enter into safe mode to remove windows password when you lost user account password, but if you forgot administrator password, you should use program to recover administrator password. Yesterday evening, I forgot my Windows admin password. In the end, I successfully retrieve the Windows password with Windows Password Seeker. It's worth a try.
So what if you changed the admin user name? And that doesn't work, is there any other way around it besides rebooting windows?
Hi
press ctrl-alt-del thrice at the login screen and at the next login screen enter user name as "administrator" and leave the password blank.
hope this solves ur problem.
SOURCE: Forgot my Password
As far as I know, there are a lot of tools and utilities that can be downloaded and used to recover, retrieve, reset windows password. However, I've tried a couple of these utilities through the years. The free software can help you, but you have to learn some computer skills and waste a lot time on learning. If you want to save more time, maybe Google third party password recovery tool or Google Window Password Seeker can help you.
I have a toshiba laptop but I can't remember my password to log in to it. I am the only user. HELP!
I have forgotten the login password of my laptop acer notebook
i have forgotton the windows login password for my emachine laptop i am the only user so please help
i have a acer laptop && i forgot the password too it && i don't now how to get on to my laptop !!?
i got a new loptop and i forgot my password
i hav the same problem and i my only suggstion is to kill the ******* THING AHHHHHHHHH
is it the windows login password or a power-on password?
Remove/reset lost Windows password you can use Windows Password Rescuer, it can reset/remove Windows 7/vista/xp/2008/2003/2000 password instantly.
I highly recommend [Daos Password Recovery Bundle 2012]. [Daos Password Recovery Bundle 2012] is an all-in-one password recovery software, which recover password for Windows, Excel, Word, Access, PowerPoint, Outlook, RAR/WinRAR, ZIP/WinZIP, PDF etc. Over 70+ types of passwords can be recovered instantly. A useful password recovery software for both newbie and expert with no technical skills required. No need to call in an expensive PC technician.
