Based on the information provided above, I am unable to provide a positive solution to your issue. I have provided some common solutions to help guide you in your search.
Most dehumidifiers have access to the fan through the front.
Below is a link to download pdf.format user's manuals. You must register to access the information, (free). You will need the information off the product data tag, then enter:
Type of product
Brand Name
Model Number
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?product.productName=Washer+-+clothes&product.brandName=maytag&product.modelNumber=mah3000ayw
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
The noise you hear is the fan which pulls air through the condenser core, puliing heat away from the condenser core and causing moisture on the core to condense into droplets. The bearing has gone out and the fan shaft and blade are moving back and forth. The fan unit will have to be replaced. The fan is removed with great difficulty; however replacements can be found on line.
