We have a Konica Minolta magicolor 2430DL printer that is printing white lines on our color copies. What do we need to change, clean, etc..? Thanks Sheila
i have been printing through wireless bt noe it refuses to print and shows errori have been printing through wireless bt noe it refuses to print and shows error
AnonymousMar 22, 2014
how to print the status of the printer consumable Konica Minolta Magicolor 3100how to print the status of the printer consumable Konica Minolta Magicolor 3100
AnonymousMar 26, 2014
what default password on konica minolta magicolor 3100what default password on konica minolta magicolor 3100
You can't post conmments that contain an email address.
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Do you have enough ink in your printer? This can be a problem. A faulty drum/roller could also be a cause which in that case will need to be replaced. Since you have done your part i guess the rest should be handeld by an expert personally.
good luck.
I had a similar problem with my 2430DL only with one fairly prominent white line instead of two. I read troubleshooting tips in manual for this problem and first suggestion was to wipe laser lens clean with a soft cloth. I did this and no more white line! If you do not have your manual please email me and I can forward you PDF manual. [email protected]
please check the transfer belt, it seems that the transfer belt is not cleaning very well, if you find same marks on TBU then you may try to clean the cleaning unit if no help, then replace TBP.
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
