I have sound but no volume control. 0 is mute but when I move the volume level to 1 it is the same level as 100. It is either on or off. It is loud enough to be heard as long as there is no noise elsewhere. Have tried all the sound controls in options. Nothing changes it. Help anyone?
My Prima Q328 also has good picture but sound is either Off (Mute) or on. Level 1 is the same as level 100 but very low. There is also buzzing and clicks coming through the speakers that appears to be a bad capacitor.
Where do we start looking to fix? Will the Monitor Output have the same problem on the Audio? My Prima Q328 also has good picture but sound is either Off (Mute) or on. Level 1 is the same as level 100 but very low. There is also buzzing and clicks coming through the speakers that appears to be a bad capacitor.
You can't post conmments that contain an email address.
I have bpl ftr21 tv I have sound but no volume control. 0 is mute but when I move the
anyone?ans will sent my e-mail id- [email protected]
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group> ---------------------------------------------------------------------- 0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute 244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn 251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up 169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
On some models, 100|AM/PM|1-- may be 100/Enter; Func|Sel may be Digicon; Level Up|R may be Control Right, Level Up/Minute or Menu Up; Level Dn|L may be Control Left, Level Dn/Hour or Menu Down; Review|Qck View may be CH Recall or Quick View; SetTime Fast may be Stereo Matrix; SetTime Slow may be Time/Day, Set Up, Clear or Menu; TV/Video/AV may be TV/AV, Video Mode, Input or A/V; Wide|TV|Loud may be Stereo Matrix, Surround or Mode; MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1 120 ENTER...........1-- 120 ENTER...........100 183 2...............2 187 3...............3 180 4...............4 184 5...............5 182 6...............6 186 7...............7 053 8...............8 057 9...............9 185 1...............A 123 A/B.............A/V 120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM 183 2...............B 187 3...............C 249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down 055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear 250 STOP............Control Left 246 PLAY............Control Right 250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left 055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up 180 4...............D 055 CHANNEL UP......Day 184 5...............E 120 ENTER...........Enter 182 6...............F 121 SHIFT STOP......Fine Tune Dwn 117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function 186 7...............G 053 8...............H 250 STOP............Hour 057 9...............I 123 A/B.............Input 181 0...............J 059 CHANNEL DOWN....K 250 STOP............Level Down 246 PLAY............Level Up 122 PROGRAM.........Menu 250 STOP............Menu Down 246 PLAY............Menu Up 246 PLAY............Minute 116 SHIFT PAUSE.....Mode 245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze 235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace 119 POWER...........Power 052 DISPLAY.........Recall 249 RECALL..........Review 248 PAUSE...........Select 122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast 122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep 116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix 116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day 056 SLEEP...........Timer 181 0...............Timer Set 056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV 123 A/B.............TV/AV 123 A/B.............Video Mode 058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up 116 SHIFT PAUSE.....Wide Hope this helps. Let me know if I can help you with anything else. JimmyC
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
Akai TV's are knwon for various issues, this is one of the ones i have had to deal with repairs for many times now, first jsut pwoer reset it, unplug it for 3-5 minutes and try another outlet, try a dvd player as well jsut o insure there is no sound, akai has no tech support as they ahve gone out of bussiness, i suggest calling the local television repair center or returning it
Run to the shop you got this tv from i got the same company tv and shok to see that so many people face problam from this brand. Hope that you have warranty
