We have the same hobby, I also have syma (S032).
These problems usually are caused by a bad battery or has begun to run out.
You say that it is recharging and also replace a new battery but no luck, right.
I think your battery is not filled with perfect, the conclusion there is a problem on the adapter which did not fill the battery fully.
Let me explain why this can happen :
The adapter (charger) has LED indicators that show that the battery is fully charged, when its LED lights. But because the adapter is already weak LED lights up when battery has not been filled completely.
As an example of my helicopter for the first time I do a battery charging one half an hour and after 2 months I did just one hour the charging indicator LED is lit but states that the battery is full.
conclusion: do not believe in LED indicator, recharge your battery in accordance with the instructions book. just ignor LED indicators.
regards,
dm
Can you take a video when you play and upload to youtube. I want to see more clearly what happened.
regards,
dm
Thanks for your video.
I know the problem, try to check all the gear that is on your 9053. because I see the rotation on the propeller is not smooth. there are some gear that serves to drive the blades, and when one of his gear is broken blades rotation was not perfect. I find your gear set for your 9053.
Follow this link to see your gear set >>http://cgi.ebay.com/Inner-Shaft-Outer-Sh...
i charged the battery for three hours, still, the blades move fast but the helicopter doesn't fly. sometimes it moves in the same place round and round but it doesn't go up. I recxeived the helicopter two days ago. We try it several times and it worked. Suddenly, without bumps or anything it stopped flying.
the led lights as you told me turn red and green.
i upload the video "problem searching", at leisure. Comment , view my helicopter and help me find the problem.
thank you
i uploaded the video under problem searching, view my helicopter and help me find the solution
